Thread: 2000 3.1 auto in need of help
Results 1 to 6 of 6
  1. #1 2000 3.1 auto in need of help
    Aug 2011
    lafayette in
    I just purchased a 2000 grand prix with the 3.1 auto. I think I may have bitten off more than I can chew and am in need of suggestions. In order for the trans to shift you have to manually shift through the gears. For instance if you have it in overdrive its threre and if your at a stop it literally tries to take off in overdrive. The lowest gear it will go into is second so I am taking off in second everytime. you also have to manually downshift as well as upshift. It had a shift selonoid code when scanned so the local shop put all three new in. No changes at all. Any help or ideas or experience would be greatly appreciated. thanks, brian
  2. #2 Re: 2000 3.1 auto in need of help
    Omaha, NE
    I'm no tranny pro, but I think that could mean that the forward band is broken.
  3. #3 Re: 2000 3.1 auto in need of help
    Aug 2011
    lafayette in
    its not the forward band it goes just fine in forward gears if i manually shift it. thanks though
  4. #4 Re: 2000 3.1 auto in need of help
    utah
    Replace the tranny with a used unit....way cheaper then tryin to fix it
  5. #5 Re: 2000 3.1 auto in need of help
    Donating Users Valhad's Avatar
    Jul 2010
    Lafayette, Indiana
    Afraid I don't have any suggestions for you, although I could recommend a local shop I've had good luck with. However, you'd be more likely to get more help from forum members here if this thread were in the correct transmission forum for your car.
    Best of Luck,
    Valhad
    You are not alone. Try looking in the transmission topic, and you'll see this current conversation that sounds very similar to yours. Sounds like some good starting points, at least: http://www.grandprixforums.net/lost-...ift-47677.html
  6. #6 Re: 2000 3.1 auto in need of help
    Aug 2011
    lafayette in
    Thanks for the tip. Ty is the exact problem I'm having but I already had Dave at Taylor trans replace all three shift Seminoles inside the side cover of the trans with no change in problem. No blown fuses. Strange
  1. 2000 GTP info center in a 2000 GT?
    By ZachBW55 in forum Visual/Body Modifications
    Last Post: 06-24-2011, 01:24 PM
  2. Auto TCS Off
    By Confusingboat in forum General Tech Discussion
    Last Post: 10-05-2010, 08:33 PM
  3. Auto Door Lock Problem-2000 GTP
    By sandjaso in forum General Tech Discussion
    Last Post: 08-31-2009, 07:25 PM
