Thread: Tranny "clicks" when I put it into gears and such...
Results 1 to 2 of 2
  1. #1 Tranny "clicks" when I put it into gears and such...
    Donating Users Tengis's Avatar
    Houston
    Title says it all. I can hear it audibly changing gears when Im sitting still and moving the shifter around.
    Good/bad? Just wondering.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  2. #2 Re: Tranny "clicks" when I put it into gears and such...
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    There is going to be a small amount of noise going from park or neutral to any gear but it shouldnt be too noticable. Make sure the mounts are all good and also check your cv joints as they can cause noises if they are sloppy.
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. GMR 1" Chain/Gears for Turbo/Twin Charged
    By japslpr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2008, 09:36 AM
  3. "Extra Clips" in 4T65E Transmission Valve Body?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2008, 03:17 PM
  4. There should be a "Forum Bugs/Suggestions" section
    By syP in forum Forum Bugs/Suggestions
    Last Post: 12-13-2007, 07:48 PM
