Thread: Just a few trans removal questions
Results 1 to 5 of 5
  1. #1 Just a few trans removal questions
    SE Level Member chrisgsx's Avatar
    Nov 2010
    Michigan
    Ok so im going to pull the trans out of my 97, i have a lift at my disposal, do you guys think it would be easier to pull the motor and trans assembly out, or disconnect the motor and leave it in? i dont have a support brace or anything..so in short is it alot more work to drop everything, or should i seperate it? Anything else to watch out for? Im also changing the rack and pinion while im at it. any comments or tips will be appriciated
    97 gtp in peices...
    01 Regal gsx 3.4mps SD headers, 1.9 mod rockers etc etc
  2. #2 Re: Just a few trans removal questions
    if you have a lift you can just hang the engine in the bay and drop the trans, so yes you do have a support method.
  3. #3 Re: Just a few trans removal questions
    Nov 2010
    Michigan
    i understand what your saying, but is leaving it all connected and droping the whole assembly alot more work?
    97 gtp in peices...
  4. #4 Re: Just a few trans removal questions
    there's a lot less to unhook, fuel lines all the wires, exhaust, and all the little things.
    the trans just needs the bell housing and the torque converter unbolted, the axles, the sifter cable, trans lines, trans mount, and a few wires.
    there's a write up how to do it here. and with the trans out you'll have a ton of room to get to the rack and swap that out with ease.
  5. #5 Re: Just a few trans removal questions
    A 4x4 and chain is all I hang engines from when i swap transmissions. Personally I prefer to take them out the bottom and like you..I don't have a lift.
  1. XAB and XBB trans code questions..
    By 00BLUEPOSGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-25-2011, 07:28 AM
  2. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
  3. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
  4. Motor & Trans Rebuild Questions
    By BlackGhost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-11-2008, 10:16 AM
