Thread: Recommended Transmission Fluid?
Results 1 to 17 of 17
  1. #1 Re: Recommended Transmission Fluid?
    Jun 2011
    Detroit, MI
    Quote Originally Posted by Zef_66 View Post
    What? Our trannys prefer Dex III? Since when? I have been running Dex VI and I wouldn't ever switch back. Dex VI runs cooler, has much better properties.
    For me, I run Valvoline synthetic Dex VI. But anything that is Dex VI should be fine.
    I think he reversed the two on accident.
    iLoveSpade
  2. #2 Re: Recommended Transmission Fluid?
    Quote Originally Posted by Hippo Machine View Post
    No, he didn't.
    Dex III was recommmend by Trannyman95, who is the resident expert on transmissions and owns Triple Edge Performance - Home Page
    I run a blend of DexVI and Transsend in the blue car. The silver car is getting DexVI...I also think it is still a better blend to run and is more easily available.
    If your going to do anything...buy a shift kit when you do the pan drop. Your transmission will thank you. Quicker shifts = less clutch/band wear.
  3. #3 Re: Recommended Transmission Fluid?
    PA
    No, he didn't.
    I know Dave and have spoke with him a couple times about tranny fluid. The fluid that he puts in all the transmission he installs is a mix. But you are correct it was a mix of Dex III. I believe he choose the mix he did because of its ability to stick to the differential. The newer Dex VI fluid is thinner and will not stick to the diff as well during burnouts.
    So the way I took it when he described it to me, unless you are doing a lot of burnouts and racing at the track, Dex VI is a better fluid to use. If you are doing racings and pit burnouts, then his recommended Dex III mix is a better choice.
    But to say that our transmissions prefer Dexron III fluid is a quite misguided.
    2001 GSE
  1. transmission fluid
    By dave2002GP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2010, 09:01 PM
  2. What transmission fluid for 98 gtp?
    By silverPGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-18-2010, 05:22 PM
  3. Transmission fluid
    By ChevMan92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 07:54 PM
  4. Recommended Trans Fluid
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 03-20-2008, 05:57 PM
  5. Transmission Fluid Thermostat
    By Zef_66 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 08:49 AM
