If I put it in 1st gear when stopped there is a whine there faintly, the second you take the shifter away from "1" on the gear selector the noise isn't as loud..it's hard to explain. If I have the car in "1" and I'm moving it whines REALLY loud, and if I move the shifter into "2", "3" or "D" before it even shifts to the next gear the whine is already gone...? When in Neutral or Park there is no whining noise. We have gone over the pullies, we just replaced the waterpump when we did the UIM/LIM gaskets, brand new tensioner as well. The car is quiet as anything aside from the motor when the car is in Park or Neutral.
I'm hoping the whining noise is just that the filter is clogged/dirty and isn't allowing adequate fluid flow. I will be ordering the shift kit either later tonight or tomorrow and we might do it Friday night or over the weekend.
Should I run a type of seafoam or any tranny additive thru the tranny before we drop the pan?
And is Valvoline DEXTRON III/Mercon pt # VV353 on Autozone the correct fluid to use when refilling?
Thanks!!
