Thread: 01 4t65e tranny shudder problem
Results 1 to 20 of 28
  1. #1 Re: 01 4t65e tranny shudder problem
    Should, or it's one firmness.
  2. #2 Re: 01 4t65e tranny shudder problem
    Jun 2011
    Willow Spring, NC
    Okay, that's all the information I need right now.
    Thanks for your help, I really appreciate it! Sounds like me and my dad have a project one night this week, or a weekend project!
    I'll update this thread if I have anymore questions!
  3. #3 Re: 01 4t65e tranny shudder problem
    It's about an hour to two if it's your first time out. That's as long as you dont' find "parts" in the pan.
  4. #4 Re: 01 4t65e tranny shudder problem
    Jun 2011
    Willow Spring, NC
    I think the tranny is in good shape, I hope there aren't any metal parts in the bottom of the pan. I've taken a magnet to some of the fluid and there aren't any metal shavings in it so that's a good sign. We have a Snap-On lift in our garage and you can almost stand under it so it should make this a rather easy project.
  5. #5 Re: 01 4t65e tranny shudder problem
    Now I hate you.
  6. #6 Re: 01 4t65e tranny shudder problem
    Jun 2011
    Willow Spring, NC
    Now I hate you.
    Haha I'm sorry! My dad's been a Subaru Certified Technician for 26+ years. He works at a Hyundai Subaru dealership working on Subarus everday of his life. He does side work for play money out of the garage. So having the lift in the garage has helped him so much.
    Here's the imp up on the lift getting waxed along with a tire rotate and brake change.
  7. #7 Re: 01 4t65e tranny shudder problem
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I've never read or heard of Maf controlling line pressure, it is used to determine shifts etc along with TPS
    The MAF has a direct effect on transmission line pressure. A dirty MAF can cause low line pressure.
    Something else on this note- Changing/Upgrading your MAF sensor to a larger one, porting your throttle body, larger intake piping ALL effect MAF signal. When you make the pathway larger you slow down airflow across the MAF sensor and guess what- lower trans line pressure, especially at WOT on the high end of the scale. Not something you think about but when you experience it first hand and see the results you never forget.
    Should I go with the 64.95 one or the 89.95 one?
    We started to offer a Combo Kit for the Transgo Shift Kit as it includes a new filter and required gaskets to install the shift kit. The basic $64.95 kit is considered a rebuilders kit and does not include any gaskets. As a bare minimum the accumulator body gasket should be replaced if you are going to install any shift kit.
    As Bill said above the shift kit will help to clean up your shifts but is not going to address your whole problem. The whine noise could be a number of things. You mention it happening in gear, but does it make the noise if sitting stopped while in gear? There are a lot of posibilities and some are fairly common in these transmissions that will cause a whine. Also check your engine accessories and idler pullies- they can fool you and make plenty of noise and a stethoscope will help isolate the source. Your slippage on take-off and banging into gear could be result of a few other problems and most likely worn seals and worn input clutch apply piston as this is fairly common. Here is more info on this- No Forward Cold
  1. 4T65E Tranny Problem. Please help me
    By swapthe98 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2010, 05:24 PM
  2. tranny shudder
    By bpm4x4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2009, 10:35 PM
  3. 2000 4T65E HD tranny in a 1998 GTP with no problem in swap......but!!
    By daytonapacecarguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-04-2009, 10:53 AM
