Thread: My shift kit has arrived! - where to start and correct procedures
Results 1 to 11 of 11
  1. #1 My shift kit has arrived! - where to start and correct procedures
    SE Level Member LePrix's Avatar
    May 2011
    Ottawa, ON
    My 4T65E shiftkit has arrived finally, tiny little box, just came with 2 rubber bands and a bag of springs. Now I want to do this once and do it right, the problem is I have to get it done at a shop and the instruction pamphlet in the shiftkit is saying all kinds of things about replacing hard parts and torque converters, I just want to install the accumulater upgrade, how do I explain this to a regular mechanic. Should I tell then to Lucas and flush? I just dont want to take any chances.
  2. #2 Re: My shift kit has arrived! - where to start and correct procedures
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    What shift kit did you go with? If its just the accumulator springs, you can do that yourself.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  3. #3 Re: My shift kit has arrived! - where to start and correct procedures
    May 2011
    Ottawa, ON
    SK4T65E from Transgo, I have no mechanical expertise.
  4. #4 Re: My shift kit has arrived! - where to start and correct procedures
    ive been looking into that kit,, how much did it run you?
    SMGPFC Member #10
  5. #5 Re: My shift kit has arrived! - where to start and correct procedures
    May 2011
    Ottawa, ON
    With taxes, shipping abs everything, $75 Canadian.
  6. #6 Re: My shift kit has arrived! - where to start and correct procedures
    wow thats alot cheaper then i was told..someone told me that it was closer to 200..thanks
    SMGPFC Member #10
  7. #7 Re: My shift kit has arrived! - where to start and correct procedures
    Jul 2010
    Coquitlam,BC,Canada
    The TransGo kit comes with a few extra parts and the instructions cover a lot more than the shift kit; ignore all that doesn't apply to you. I think it was page 1 that showed the accumulator, so just focus on that.
    My buddy installed mine a few weeks ago. If he wasn't so anal and meticulous (sp?) it would have taken less than 30 minutes.
    Here is my write-up: clicky clicky.
    As for the price of the kit, I was quoted $120 from a wholesaler, but I didn't trust him. I had my tech buddy call the same place and his cost was $72, so he ordered it up for me.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: My shift kit has arrived! - where to start and correct procedures
    May 2011
    Ottawa, ON
    Bronco, I'm going to upload some pictures for extra clarification:
    The box, i'm pretty sure I got the right kit :
    Two separate baggies with rubber bands:
    Tiny bag with spring:
    Big bag of springs:
    Manual that wants me to do a rebuild :
  9. #9 Re: My shift kit has arrived! - where to start and correct procedures
    Dec 2008
    Lawndale, CA
    Just use the shift kit write up. Should be all you need.
    http://www.grandprixforums.net/shift_kit.php
  10. #10 Re: My shift kit has arrived! - where to start and correct procedures
    May 2011
    Ottawa, ON
    Any settings or options I should make a mechanic aware of? And should the tranny get serviced or conditioned before or after?
  11. #11 Re: My shift kit has arrived! - where to start and correct procedures
    just drain the trans fluid, put in shift kit and then put the filter and pan back on and re fill with 7-8 quarts of trans fluid and thats it.
  1. GM radio unlock procedures
    By Swash in forum How To Write-Ups/Tech Tips
    Last Post: 08-07-2012, 11:15 PM
  2. big red has arrived
    By beckys2000gt in forum Off Topic Discussion
    Last Post: 06-06-2010, 02:07 PM
  3. Won't shift or start
    By SDGTP99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-23-2010, 03:35 PM
  4. DRL disable procedures?
    By Cowboybebop in forum General Tech Discussion
    Last Post: 07-22-2009, 09:41 AM
  5. He has arrived
    By Injun #4 in forum Off Topic Discussion
    Last Post: 07-10-2009, 12:23 AM
