Thread: Wont upshift 2-3 but down shifts 4-3
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #1 Re: Wont upshift 2-3 but down shifts 4-3
    SE Level Member bstuby's Avatar
    charleston, IL
    No prob... Thank you for the advice.
    98 GTP/ SD Headers, 180 T Stat, AL 104's, CAI, Intense pcm, 3.4 thrasher mps
    98 TA, Pacesetter coated LT/ ORY/ LS6 Intake/ SLP Lid/ Magnaflow CB/ Tuned
  2. #2 Re: Wont upshift 2-3 but down shifts 4-3
    May 2011
    Lancaster, OH
    Thanks, mine has 204k so it has had a good run too, I will just drive it until its completly gone, then get it fixed, hoping it will last until tax time ( gotta love being broke)
  3. #3 Re: Wont upshift 2-3 but down shifts 4-3
    charleston, IL
    Need a little more advice. I plan on keeping the car for another year or two, but not forever. Should I spend the $1800 on TEP trans? I cant see spending that much money on a trans, since it would be worth more than half of the car especially if I dont plan on keeping it. Should I just hit up Ed Morad and get a jy trans and call it done? Or if anyone else has any other ideas, I would really appreciate it.
  4. #4 Re: Wont upshift 2-3 but down shifts 4-3
    Check car-part.com for a trans. It'll list by area/distance to your zip code etc. I've found them for 200-300 with 6month unlimited mileage warranty before. Downside is ..labor isn't warrantied, but hey.. 200-300
  5. #5 Re: Wont upshift 2-3 but down shifts 4-3
    charleston, IL
    If I went with a GT trans, I would get 3.29 gears and just have to swap in my hd axle, and diff cover, and get a tune right? Or did I miss something? Also, any trans from a 98 to a 00 will work too?
  6. #6 Re: Wont upshift 2-3 but down shifts 4-3
    98-02 will work.
    You may need to swap the prndl (2 13mm bolts, 1 15mm nut), HD diff cover, HD diff, HD output shaft (literally 2 13mm bolts by the time you get that far). Yes on 3.29's and programming.
    Got all this stuff detailed out somewhere.. or can toss it up again when you are ready.
  7. #7 Re: Wont upshift 2-3 but down shifts 4-3
    charleston, IL
    Got all this stuff detailed out somewhere.. or can toss it up again when you are ready.[/QUOTE]
    I thought you were saying you had all this info somewhere else.
    I misunderstood you.
  8. #8 Re: Wont upshift 2-3 but down shifts 4-3
    charleston, IL
    Which would be better to get. HD or non-hd. If you could post a link, I would appreciate it.
  9. #9 Re: Wont upshift 2-3 but down shifts 4-3
    a link to what? www.car-part.com ?
    Depends on what you want to do. If you want 3.29's then get a non-hd and swap parts. If you want stock gears, get an HD
  1. Max engine torque for upshift
    By Juanmiguel in forum PCM Tuning
    Last Post: 05-15-2011, 02:27 PM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. dhp 6k shifts
    By blowfishRus6 in forum PCM Tuning
    Last Post: 10-11-2009, 11:16 AM
  4. Newb Question about 4th gear upshift
    By mtcimpala in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-25-2009, 07:38 PM
  5. 1974 Upshift??
    By 74GrandPrix in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 08-09-2009, 03:28 PM
