Thread: 1998 gtp wont drive in 4th NO SLIPPING THO
Results 1 to 20 of 51
Threaded View
  1. #6 Re: 1998 gtp wont stay in drive 4th gear ?? and othe problems
    Grand Rapids, MI
    mk. let me show you.
    on the LEFT, is a used hardened 4th gear hub (03 models +).
    on the RIGHT is a pre 03 hub which is NOT hardened and as you can see, the splines are worn down. this is what has happened with you most likely. it slips in 4th when you let off because there is no pressure exerted on it and it can catch its grooves. when under pressure, it won't go in because the engagement teeth are worn down as you see in the pic.
    read up more on it maybe you can find another probable cause..
    Triple Edge Performance - Home Page
    good luck
  1. Transmission is slipping in drive
    By KarenC in forum General Tech Discussion
    Last Post: 06-01-2011, 03:22 PM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. 1998 grand prix GT wont crank
    By li0nhe4rtt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2010, 04:23 AM
