Thread: 1998 gtp wont drive in 4th NO SLIPPING THO
Page 3 of 3 FirstFirst 123
Results 41 to 51 of 51
  1. #41 Re: 1998 gtp wont drive in 4th NO SLIPPING THO
    Put your paperclip away. That was no longer possible after 1994 cars. Your car wants a code reader. Many parts stores will pull the codes for free.
    likely you have a stuck open thermostat,.
  2. #42 Re: 1998 gtp wont drive in 4th NO SLIPPING THO
    May 2011
    michigan
    on the thermostat cant a bad one cauz bad mpg? somthing with the cars computer telling it to give the motor more fuel cuz its telling it that the motor is cold? or something along those lines?
  3. #43 Re: 1998 gtp wont drive in 4th NO SLIPPING THO
    May 2011
    michigan
    anyone here do the spline swap? how hard is it to do 1-10 im very mechanical and fix all my stuff myself.
  4. #44 Re: 1998 gtp wont drive in 4th NO SLIPPING THO
    Akron Ohio
    Quote Originally Posted by beno420 View Post
  5. #45 Re: 1998 gtp wont drive in 4th NO SLIPPING THO
    Yes a thermostat will cause poor mpgs, that's if you get good mpgs to begin with. But.. a bad coolant sensor (less likely, but possible) could tell the dash one thing and the pcm another.
    Yeah..I've done the 4th clutch hub shaft swap. I've also written it out and detailed it a few times here. Pretty sure I even said which bolts need to come out and which don't to keep the VB on teh channel plate. Search away my friend..search away.
  6. #46 Re: 1998 gtp wont drive in 4th NO SLIPPING THO
    utah
    So much win and so much fail in this thread
  7. #47 Re: 1998 gtp wont drive in 4th NO SLIPPING THO
    May 2011
    Chicago, IL
    BillBoost37 When my 1-2 solenoid went bad it was only causing 1st to act up. replaced it and it was fine.
  8. #48 Re: 1998 gtp wont drive in 4th NO SLIPPING THO
    May 2011
    michigan
    ok i changed my thermostate and ot had a 190 in it and i put in a 180 and the car still only shows around 120-140 on the dash. where is the coolant temp sensor located? and does anyone know if transmission not working right will throw a code? i will do get codes done at autozone asap
  9. #49 Re: 1998 gtp wont drive in 4th NO SLIPPING THO
    May 2011
    michigan
    and the cars shows an average of 15.4 mpg
  10. #50 Re: 1998 gtp wont drive in 4th NO SLIPPING THO
    Grand Rapids, MI
    well if you're stock you should have kept the 190.
    dont mind the avg. it could be driving habits it could be a lot of things. just make sure you have a good tune up then calculate it by hand. then go from there.
  11. #51 Re: 1998 gtp wont drive in 4th NO SLIPPING THO
    utah
    Coolant temp sensor is in theLIM under the thermostat housing
  1. Transmission is slipping in drive
    By KarenC in forum General Tech Discussion
    Last Post: 06-01-2011, 03:22 PM
  2. 1998 grand prix gt wont randomly wont start!!
    By franklin829 in forum General Tech Discussion
    Last Post: 01-18-2011, 01:26 PM
  3. 1998 grand prix GT wont crank
    By li0nhe4rtt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2010, 04:23 AM
