Thread: Brown trans fluid, drain and refill?
Results 1 to 4 of 4
  1. #1 Brown trans fluid, drain and refill?
    SE Level Member KZOO3800's Avatar
    Nov 2010
    Kalamazoo, MI
    I've changed my coolant recently and change my engine oil often, so its only natural that I closely watch my trans fluid.
    I got the car 6K miles ago and the color was still red. It is now definitely turning light brown, wiping it on a napkin was all I had to do to see this.
    Is it advisable to simply drain the old fluid out and put new fluid in?
    I read a few other posts about people that advised dropping the pan to change the filter and clean some stuff up too. If I could that without special tools I'd like to, just can't find a post on how to do it.
    Any advice would be awesome.
  2. #2 Re: Brown trans fluid, drain and refill?
    Pennsylvania
    Click any image for a larger image
    All that's really needed is a socket, a drain pan to catch the fluid (it's a big mess) and a few rags.
    You'll also wanna replace the filter that sits just inside of the pan which can be a *****.
    Now is when you want to catch it, light brown... it's when it gets dark and burnt that you should begin to worry.
  3. #3 Re: Brown trans fluid, drain and refill?
    Once the car is jacked or on ramps. It's 20 10mm bolts. Reassemble with 10ft lbs aka 120 inch lbs of torque. nothing really special tool wise.
  4. #4 Re: Brown trans fluid, drain and refill?
    Nov 2010
    Kalamazoo, MI
    I took the GP up to a trans place in my hometown, they did a full vehicle inspection, installed new filter, installed new gasket, and told me from what they can see the trans is in great shape. All for $100 too!
  1. Leaking oil or trans fluid?
    By zildjian102 in forum General Tech Discussion
    Last Post: 10-30-2010, 02:17 PM
  2. Drain Plug in Trans pan
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-04-2010, 11:32 AM
  3. radiator drain o-ring size? FAILED motormite drain.
    By alacran in forum General Tech Discussion
    Last Post: 04-03-2010, 08:16 PM
  4. There's trans fluid everywhere!!
    By FuglyGTP in forum General Tech Discussion
    Last Post: 09-05-2009, 05:08 PM
  5. Trans. Fluid?
    By BwolfGT in forum General Tech Discussion
    Last Post: 04-11-2009, 05:26 PM
