Wasn't sure how to move my thread to the transmission forum so I just reposted...
Experiencing RPM surges and transmission slips while in Manual, tapshift mode in my 08' GXP. Driving in the mountains I try to engine brake if possible to avoid heat build up on the brakes, when I go from 3rd to 2nd at highway speeds the RPM will jump, come back down, and repeat, the car eventually slows down and it goes away. If I go from 2nd to 1st with my foot off the gas it's even worse as the car will drop out of gear completely, once I reengage the throttle it catches and slams into gear. If I put the car in Drive it functions just fine it seems, then again the downshift points don't really put the car into a lower gear at high rpm so it's hard to tell. Any idea what is going on here? Car is at the dealership now for a separate issue which they found lifter issues related to a ticking noise...they are repairing it now, this has been an ongoing issue though nothing new. This new RPM surging issue came after I made the appointment.
1. Could it be the lifters issue causing the RPM surging? Some issue with the PCV, vacuum?
2. Don't usually use Octane booster but I threw some in the tank for the hell of it last fill up, this issue started shortly after. Being at high altitude I just realized that the octane requirement is less. What's the chance the octane booster messed up my timing and is causing this issue?
