Thread: weird problem with 98 gtp
Results 1 to 14 of 14
  1. #1 Re: weird problem with 98 gtp
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    Sounds like mine... I had a cracked filter neck and it would do the same thing. It tore up my 5-6k mile old tranny and ended up replacing it. I personally wouldn't waste the money on fluid and a fliter cause even if it does work for a while the trans life is probably way way shortened. I replaced my filter and fluid and cleaned all the mud/metal out of the pan filled it back with new fluid and it went a couple weeks and lost 2nd gear then about 3 weeks and it lost 4th gear. My $102.50 4t65e-hd from pullapart is still going strong...
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  2. #2 Re: weird problem with 98 gtp
    GT Level Member nicks98gtp's Avatar
    michigan
    update: today i bought an external cooler, and some new fluid. installed the cooler, ran the return line to it, and put the pressure line into a garbage can. started it up, and when it started to pump fluid out the press. line i kept feeding it with new fluid, after about 2 minutes the milky brown crap that was in it, started to flow a decent red color, so i shut it down, hooked up the pressure line to the cooler, topped it off and drove it. no more lost gears after the ~3 miles, but under 1/2 - 3/4 acceleration from a stop the car shudders, i let off get back in it and its fine. and on a hard run through first gear it slipped right at the shift point, then slammed into 2nd. shifts fine under normal acceleration/take offs. also theres a clunk, audible, and you can feel it when the car goes into reverse, or when you manually downshift it through the gears. any suggestions? and as far as the mixed fluid, it didnt mix with any coolant thank god. any ideas on what could cause the clunk, slippign under launches? i ran it with my 18 inch rims, with 225/50/18 tires on it, and it would not break them loose. am i wrong or should it not break that size or a tire loose? any input would be appreciated thanks guys
  1. Help with weird KR problem.
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2011, 06:53 PM
  2. Really weird problem!
    By pyccke87 in forum General Tech Discussion
    Last Post: 10-03-2009, 10:22 PM
  3. weird problem???
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2009, 12:44 PM
  4. Weird noise problem!
    By GTP4 in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2009, 11:41 AM
