Thread: weird problem with 98 gtp
Results 1 to 14 of 14
  1. #1 Re: weird problem with 98 gtp
    I'm in agreement, something is probably clogging the filter. No fluid, no movement.
    As for the mud, is it dark brown type mud? That's clutch material. Water in the trans fluid (oil) would appear milky reddish. FWIW typically you will get trans fluid into the coolant and not coolant into the trans fluid. This is because the trans fluid is pressurized higher than the radiator.
    Likely a seal is not quite right and that caused some slippage and the clutches to wear quick, build up in the pan and starve the trans.
  2. #2 Re: weird problem with 98 gtp
    GT Level Member nicks98gtp's Avatar
    michigan
    yeah the mud iteself is real dark brown, but the fluid looks like chocolate milk, no reddish tint at all in it.
  3. #3 Re: weird problem with 98 gtp
    Not good either way huh?
  4. #4 Re: weird problem with 98 gtp
    michigan
    not at all lol. im gonna try and external cooler, new filter, and flush it out, and see what happens, if it slips or has any issues the guys gonna rebuild it again. so its a pin, but at least hes holding up his end
  5. #5 Re: weird problem with 98 gtp
    Super.... that's great to hear.
  1. Help with weird KR problem.
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-18-2011, 06:53 PM
  2. Really weird problem!
    By pyccke87 in forum General Tech Discussion
    Last Post: 10-03-2009, 10:22 PM
  3. weird problem???
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2009, 12:44 PM
  4. Weird noise problem!
    By GTP4 in forum Audio, Security & Visual Electronics
    Last Post: 04-22-2009, 11:41 AM
