Thread: Transmission/ electrical? problems Diagnostics
Results 1 to 3 of 3
  1. #1 Transmission/ electrical? problems Diagnostics
    SE Level Member hondo's Avatar
    Salt Lake City, Utah
    Alright, here is my situation. i have a few problems with my car that are septate but i think all from the same source.
    NO 4th Gear
    False neutral when shift knob is in D.
    Tach not working on occasion. (when on the brakes)
    TCS light on.
    I have had the problems for a while now and until i noticed the tranny they havent bothered me too bad. I really only noticed the tranny becdause of a recent road trip. (I never go on the freeway so i never use 4th gear) my RPMs were waaay to high and it would go into a false neutral whenever i would let off. and i got terrible gas mileage so it got me wondering what was wrong with the car and i have no overdrive.
    Im thinking electrical. what about you guys? the tach and tcs act up when i go through a puddle or its raining outside and the first time it ever happened was right after i washed my car.
    Any opinions? similar problems?
  2. #2 Re: Transmission/ electrical? problems Diagnostics
    St. Louis
    The lack of 4th (overdrive) and "false neutral" sound like the 4th clutch hub is stripped and you lost OD. If you manually drop it into 3 do the RPMs change?
    On the tach/TCS issue I would check the harness for loose/bare wiring as it sounds like it's grounding/shorting out and causing issues.
  3. #3 Re: Transmission/ electrical? problems Diagnostics
    if i put it into third the neutral problem goes away. but i already replaced a tranny a few thousand miles ago andit has less than 100k and has never had a problem.
  1. electrical problems
    By bradkonkal in forum General Tech Discussion
    Last Post: 06-22-2011, 02:58 PM
  2. PLEASE HELP ME! electrical problems
    By tomshaze in forum 04+ Specifics
    Last Post: 09-04-2010, 11:43 AM
  3. A/C Electrical Problems
    By ryanrice in forum General Tech Discussion
    Last Post: 05-24-2010, 10:43 PM
  4. Electrical Problems 98 GTP
    By KawaFord in forum General Tech Discussion
    Last Post: 07-31-2009, 08:20 AM
  5. Electrical problems
    By Baumku in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-21-2009, 09:31 PM
