Alright, here are my findings from this weekend:
I listened to all of the pullies, alternator, power steering, water pump, idler, a/c compressor, and none of them seemed bad. I was pleasantly surprised to hear the water pump makes a soothing swooshing type noise through the scope.... kinda helped to relax me with all this aggravationBut just to be sure, I did take the serpentine belt off and ran the engine (briefly) with no belt, and the noise persisted, so I am sure it is nothing being driven from the belt. (Wish I would have thought to do this before I replaced the PS pump and wasted that time and $).
Next, I moved on to the transmission, I listened to the bell housing, and the noise was a very mild (faint & non-distinct) grumble, did not sound like a whine through the scope, but more like a bearing possibly? The noise seemed slightly louder to the far driver side of the housing, as opposed to clsoer to the middle of the housing straight down from side of the engine intake. I dont know, as I am new at using the scope to listen for noises, so I am not sure exactly what I should be hearing should sound like. I listened through the trans pan under the car, and it was very similar to the bellhousing from the top. Then I listened to the trans cooler lines (the metal ones right near where they exit the trans) and I could hear a distinct grumble through both lines, kind of sounded a little like a bad bearing type noise, or a bearing with one ball removed and replaced with a small rock instead. The noise was loudest near the trans, and inauduble in the trans cooler lines at the radiator (they are isolated by rubber hose). I think this tells me the noise is certainly in the trans, and not just the coolant flow through the lines. And very near where the lines go into the trans.
There is no difference in the noise regarding hard or soft accelleration, so I do not think it is the torque converter, at least these tests dont appear to point in that dirrection I dont think, but I will deffer final judgement to the expert.
When it is making the noise, I put it in 1st, and there was no difference in the noise. It was still present, but no louder or softer.
So here is my 3 part question:
1. What in your opinion is bad and/or a likely culprit? Is there a way to verify this before or during the repair so I dont get it back together and still hear the whine?
2. Is it servicable through removing the side cover, or do I have to pull the whole trans from the vehicle?
3. If I choose to do this repair myself, are there any special tools I will require that a normal well stocked tool chest for someone that dosent do trans work wouldnt have?
