Thread: 4T65EHD Build Advise
Results 1 to 18 of 18
  1. #1 4T65EHD Build Advise
    Donating Users moddman's Avatar
    Midwest
    I building my original trans into a custom race trans. I leaning toward 3.29 gears,7/8 hv chain, hardened 4th hub,kevlar clutch packs,ntc 3000 stall converter,transgo shift kit,and fully updated sonnex/valve body. Anything I am missing please chime in. I want this thing to move so help me out with suggestions if mine are not accurate. Thanks in advance........
    Last edited by moddman; 03-03-2011 at 02:40 AM. Reason: Trans I bought was received with a cracked/damaged case.
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  2. #2 Re: 4T65EHD Build Advise
    Grand Island, Nebraska
    Input shaft? thats like the first thing that breaks isnt it?
  3. #3 Re: 4T65EHD Build Advise
    Banned
    Sioux Falls, SD
    If your going to get a shift kit, get one from a transmisson shop where they replace valves. Its running me about 160 to get that put in mine.
  4. #4 Re: 4T65EHD Build Advise
    Where are all these parts coming from? I've never heard of the clutches referred to as Kevlar. Usually it's by brand name like Raybestos red's or Borg Warner.
    What's your expected power level?
  5. #5 Re: 4T65EHD Build Advise
    Midwest
    I am following Daves advise on clutch packs borg warner seems like the way to go as seen here.
    http://www.grandprixforums.net/clutc...ther-3200.html
    3.4" ZZP MPS Pull
  6. #6 Re: 4T65EHD Build Advise
    Ok good.
    How about the second question?
  7. #7 Re: 4T65EHD Build Advise
    Daves site says that after 280 WHP the trans must basically be built for your car and power level.
    There are no good chain setups anymore.
    the 7/8ths stretches, the BW GXP chain snaps like stock but is stronger etc.
  8. #8 Re: 4T65EHD Build Advise
    Quote Originally Posted by That Canadian Guy View Post
    what about WBS 15/16th chain?
  9. #9 Re: 4T65EHD Build Advise
    Do you plan on making track passes?
    If no, then under 280 WHP and no slicks you should be good with the upgraded stock set.
    Victor smalls has been on his stock transmission for a while...
  10. #10 Re: 4T65EHD Build Advise
    Charles City, IA
    15/16 chain is actually weaker than the 7/8 form what I hear.
    SMGPFC Two Nipple General
  11. #11 Re: 4T65EHD Build Advise
    The newer dual V8 chains are better than the old V6, but still not super strong
    7/8 stretches and takes a F'n Sheetload of abuse, ask my right foot
    15/16's.. here's my thoughts on that, dunno if this was the same one WBS sells, but it's common knowledge they snap before they stretch.
    Supposedly one of the vendors is working to make a 1".
  12. #12 Re: 4T65EHD Build Advise
    WBS also says they sell the 1" if you buy the whole tranny, but its like 900 bucks...
  13. #13 Re: 4T65EHD Build Advise
    Midwest
    Quote Originally Posted by miker56 View Post
    Thanks for the heads up....mine is going to be the same way....$150 is what they're charging me.
    3.4" ZZP MPS Pull
  14. #14 Re: 4T65EHD Build Advise
    Midwest
    Ok good.
    I'm making about 220 at the wheels now. I plan on putting in a cam later a VS or XP not sure which one yet. I am planning on putting on my 3.25 pulley and retuning. So the cam and the pulley should add roughly 35-55hp so make that about 275whp max which sounds about right.
    3.4" ZZP MPS Pull
  15. #15 Re: 4T65EHD Build Advise
    Midwest
    I hoping its made in North America cause I read that Asian parts have been made for transmissions such as chains which are not as strong as the Morse chains which are made in North America (USA Mexico Canada) and they break within a few thousand miles. So maybe the ones that are breaking are being made overseas....just my thoughts on this.
    3.4" ZZP MPS Pull
  16. #16 Re: 4T65EHD Build Advise
    No, sorry.. 15/16" suck. Ask Dave...
  17. #17 Re: 4T65EHD Build Advise
    i was gonna say, there must be a reason he only offers the 7/8ths on his website.
  18. #18 Re: 4T65EHD Build Advise
    Why sell "gonna break"?
  1. 4T65EHD Problems
    By moddman in forum General Tech Discussion
    Last Post: 02-19-2011, 08:48 PM
  2. **NEED ADVISE** please help
    By tmackster in forum General Tech Discussion
    Last Post: 05-05-2010, 10:40 PM
  3. Hello and some advise please.
    By Pontiacfan in forum Introductions/Noob Questions
    Last Post: 09-03-2009, 05:03 PM
  4. Some Advise Please
    By Scott B in forum General Tech Discussion
    Last Post: 04-19-2008, 01:08 PM
