2000 GTP with 115k miles, I just bought it. It had no overdirve and a tranny shutter. I did a service on the trans. Filter and fluid plus a lil Lucas and still no OD. It shifts under power just fine, Anyone have an idea as to what might be going on?![]()
If you would have tried a search, you would have found that your 4th clutch hub is stripped, you need a new trans or a rebuild.
Yeah, you bought a car without 4th, you will need a new tranny for sure.
Yes..and being in AridZona.. you may have a couple local buddies of mine near you. One does work on transmissions. To swap out a 4th hub shaft (if that's the issue) isn't bad with the trans in the car.
You don't need a whole new trans... just the 4th gear clutch shaft. Pick up a Hardened one from ZZP for like $80, then gaskets, then some fluid and swap out the shaft, can be done with the trans still in the car..
My 4th has been gone for over a year now.. i just drive it like that haha.
No DTC codes, computer is telling the trans to shift and the lockout is working properly but yet no 4th gear. Looks like i will be giving it a new 4th gear. Thanks you all for your input as to I am new to the GTP group. Only one regret; I DIDNT BUY ONE EARLIER!!! even without 4th gear, a very fun car to drive!
FWIW ZZP is very overpriced on the shaft.
TEP has them cheaper and sometimes you can find a name your price on ebay. I've gotten a couple for $45 shipped.
Also if your not comfortable doing the work yourlsef let Bill know hes very reputable on here and can hook you up with one of his buddies![]()
Corey...next time you see Bob, tell him Majestic Teal is a girlie color.
Yeah..Thomas is the man.
Last off topic post. It's a color Gm used for 1 year on bonneville, and I think GP's too. In sun it'll look green, dusk...and it's purple then teal .. it's a cool color. But busting a buddies chops is always in order.
