Thread: Transmission slipping?
Results 1 to 3 of 3
  1. #1 Transmission slipping?
    May 2008
    What's up guys? Alright well I have a 2000 Grand Prix GT and it seems to be having transmission problems. Big surprise, right? Lol OK well the problem is that if I am sitting in park and put it in gear(Forward or reverse) It feels likes it having a little trouble finding the gear and then when it does its kicks. I mean this isnt a huge problem, its not a situation where i cant drive the thing. I would just like to diagnose the problem. I feel like the Transmission is slipping sometimes also, when i push the pedal all the way down it really takes a while to shift and when it does its a fairly rough shift. Could it be a CV axle? I do here faint clicking alot when I'm driving.
  2. #2 Re: Transmission slipping?
    PA
    First things first. Check the transmission fluid level.
    Make sure the car is warmed up, running, and in park on a level surface. Then pull the dipstick and check the fluid level. If it is low, then you need to add some fluid.
    Also, you can check the fluid condition. It should be a reddish color. Anything other than that and you should consider a transmission fluid and filter change.
    2001 GSE
  3. #3 Re: Transmission slipping?
    IIRC, check the fluid at a level surface as well as while the cars running at operating temps.
  1. Trans Slipping - HELP!!
    By coolken84 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-01-2011, 01:17 PM
  2. which onew is my transmission?
    By Dupuig in forum Pre-1988 3 speed Automatic TH-125C (3T40)
    Last Post: 05-25-2008, 11:41 PM
  3. 1-2 wot slipping shift
    By solow172 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-18-2008, 10:10 PM
  4. transmission slipping occaisionaly
    By twistin*6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-18-2008, 08:35 PM
  5. Transmission help needed
    By smokinum in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2008, 10:23 AM
