definitely sounds like the output shaft seal... as for the shudder from 1 -2 mine used to do the same thing at a low speed downshift... about a month ago I changed all the solenoids in the trans and it hasn't done it since...
Thanks for the help. Drove today for an hour or two, seems to be leaking more (dripping on ground).
How hard it is to replace the seal? Can I remove the drive shaft without removing strut bolts?
Whats the best way to press the seal in?
As for the solenoid: where is it located?
