Thread: Perfect Shift Mode
Results 1 to 6 of 6
  1. #1 Perfect Shift Mode
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    I have a transmission that does not have perfect shift mode meaning there is no button on the shifter. Does anyone know what you have to do in order to add perfect shift mode?
  2. #2 Re: Perfect Shift Mode
    You have it. The 97-00 cars had the button, the 01 plus have it put into the cars PCM to activate when the throttle is pressed down more than 3/4--WOT. So no need for the button.
  3. #3 Re: Perfect Shift Mode
    Nov 2010
    Illinois
    oh ok. Great! thanks a lot
  4. #4 Re: Perfect Shift Mode
    Nov 2008
    Waterloo, Iowa
    Performance Shift maybe?
    Either way, it might just be missing the correct knob. Check it and see if there wire is there.
  5. #5 Re: Perfect Shift Mode
    Nov 2008
    Waterloo, Iowa
    I completely missed the fact that your car was an 02, so what FFDP said is correct.
  6. #6 Re: Perfect Shift Mode
    You'd need to run the wire, then have more aggressive tables put into the perf shift mode in the PCM.
    Its not worth it.
    A good tranny tune alone would be better.
    a nice progressive one that switches between smooth for light throttle to harsh when you're in the gas.
  1. 1998 GTP DIC Performance shift mode does not work on my 2000 GTP?? help?
    By okesongtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2010, 03:53 PM
  2. My friends GTP is stuck in performance shift mode?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 08-05-2010, 09:02 AM
  3. Performance shift mode on 05+
    By GrandprixGearhead in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2009, 05:15 PM
  4. Performance shift mode?
    By brodyman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-14-2009, 02:39 PM
  5. Performance Shift Mode
    By pski920 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-23-2009, 05:24 PM
