Thread: Startup issue with the GTP
Results 1 to 4 of 4
  1. #1 Startup issue with the GTP
    utah
    So after doing a transmission rebuild and getting the computer reprogrammed, everything seems to be working great...EXCEPT...
    When I start the car after sitting overnight or for a few hours and shift into reverse it seems like it does not want to reverse. If I give it some gas it does go but it seems like it takes more effort. However, if I go back into park while its still running and then go back into reverse, it works perfect. I took it back to the shop I had it rebuilt at, and they said it was nothing to worry about...but I just want to double check with you guys.
  2. #2 Re: Startup issue with the GTP
    Jul 2008
    sumter,south carolina
    nothing to worry about? really? it should be 100% correct if it just got rebuilt. tell those dudes to fix that sh!t
    02 GTP with mods 05 GP for DD
  3. #3 Re: Startup issue with the GTP
    Jersey
    no one can rebuild these transmissions right, except for trannyman. Get a hold of him. Your car shouldn't be doing that at all
    16' wrx sti- stock
  4. #4 Re: Startup issue with the GTP
    Jul 2008
    should have gotten triple edge from the get go.... id be making death threats to the ppl who rebuilt it...
  1. Problem car bogging after startup
    By Shang TI in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-19-2010, 04:22 AM
  2. Bad lag on startup & accelleration
    By Jsedor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-11-2009, 03:07 PM
  3. knock at startup
    By Jakegday in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2009, 08:01 AM
  4. oil burn at startup?
    By Golgo13 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2008, 07:18 PM
  5. Hard startup and noise
    By GreenNirvana101 in forum General Tech Discussion
    Last Post: 05-31-2008, 04:58 PM
