Thread: p1629 with newly installed built trans
Results 1 to 9 of 9
  1. #1 p1629 with newly installed built trans
    Milwaukee
    Ok, so I bought usmcz28's old built trans a couple months back. Finally got around to installing it this past weekend. It ran last night enough to get around the block(did the swap at my friends house). So I go to pick it up today and it won't stay running for more than 5 seconds and shuts off. The car is a gt and the old trans had 3.29's in the stock trans. What needs to change in the PCM to make the trans be recognizable by the PCM? The trans also has a zzp 2500 stall tc, if that means anything.
    Current: 2004 Dale Jr Monte SS #1324/2883
  2. #2 Re: p1629 with newly installed built trans
    Jul 2008
    sumter,south carolina
    something is wrong with security. flashing security light?
    02 GTP with mods 05 GP for DD
  3. #3 Re: p1629 with newly installed built trans
    Milwaukee
    no security light.
    Could it be the key that i used? They key that i used hasnt been used in over a year. I had to use this key because the original key was locked in my friends garage where i did the swap.
  4. #4 Re: p1629 with newly installed built trans
    Jul 2008
    could be... try the original key. if it still starts up and dies... u might have to do a security re-learn.
  5. #5 Re: p1629 with newly installed built trans
    HUDSON
    The security problem you are facing happend to me once, all I did to correct it was lock the car with the remote, and unlocked withe the remote, and then it started like normal.
    Dean
  6. #6 Re: p1629 with newly installed built trans
    Milwaukee
    The key i used was the first time i used it in over a yr and a half, therefor the tune currently on the PCM as wel as the PCM itself, did not recognize the key(the pcm is from a 2000 regal).
    I used the other key and it works perfecty fine!
  7. #7 Re: p1629 with newly installed built trans
    Jul 2008
    cool beans... glad ya got it figured out.
  8. #8 Re: p1629 with newly installed built trans
    GT Level Member AmericanRiceEater's Avatar
    New York
    cool beans
    Black 2000 GTP Coupe. SSAutoChrome headers, K&N Cold Air Intake, Reptile Tuned PCM, 3.4" ZZP MPS, 104 Autolites & 180 Stat.
    PS3 Online: Zirpola (Dont use mic.)
  9. #9 Re: p1629 with newly installed built trans
    Outer Space
    Glad you got it fixed!
    02 GTP 13.6 @ 100mph - SOLD
  1. Got a new performance transmission built and installed, same problems occuring.
    By Lsick7 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-19-2010, 05:00 PM
  2. TEP trans installed.....
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 10-08-2009, 08:20 PM
  3. Please help...P1629
    By jessie9284 in forum General Tech Discussion
    Last Post: 06-12-2009, 04:43 AM
  4. newly painted motor mounts
    By GP2003GT in forum Visual/Body Modifications
    Last Post: 05-08-2008, 02:36 PM
