Thread: will this work...
Results 1 to 7 of 7
  1. #1 will this work...
    SE Level Member Myprixxx's Avatar
    Apr 2008
    Decatur, IL
    is it possible to put an l67 tranny in a car with an l36? i have an old tranny lying around that is not being used but i am capable of finding a gt with a blown tranny cheap. i have a DHP tuner to change anything around in the pcm if need be, and if i remember right the axles are different sizes. But the basic question is can a GTP tranny be swapped into a GT and what is necessary to do so. thanks!
    i knew this guy wasn't b/sing.
    michigan people have better stuff to do, like finding jobs or avoiding robbery.
    quoted from noreasonwhyy
    GenV, Full sized I/C, HAI, 3.0 MPS, N* TB
  2. #2 Re: will this work...
    its pretty much a direct swap. you have the tuner so youll be able to change the transmission files and run it just fine.
  3. #3 Re: will this work...
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The passenger side axle is different, otherwise it will be a direct swap (assuming they're the same year).
    Yes, the gearing will need to be changed in the PCM, but be aware the lower gearing in the unit from the GTP will probably make your car seem sluggish on the low end.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: will this work...
    Apr 2008
    Decatur, IL
    that wouldnt be a huge problem to me, and they are different years but i think i should be able to get it, thanks guys
  5. #5 Re: will this work...
    QCA, IA
    What years are we talking? There are some serious differences between some of them.
  6. #6 Re: will this work...
    Apr 2008
    Decatur, IL
    A 2000 into a 98 is what I'm looking at now
  7. #7 Re: will this work...
    QCA, IA
    That's not too bad, the main difference will be the cooler line fittings. There's a sticky about them if you need that info.
  1. Would this work?
    By GTPcoupe in forum General Tech Discussion
    Last Post: 05-10-2010, 11:47 AM
  2. cant get sub to work
    By CMURDAx in forum Audio, Security & Visual Electronics
    Last Post: 01-16-2010, 04:27 PM
  3. Will these work??
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 09-28-2009, 08:00 PM
  4. my way to work
    By mileyguard in forum Off Topic Discussion
    Last Post: 03-25-2009, 09:33 PM
  5. G.I. In Fab work
    By J_Ferguson in forum Off Topic Discussion
    Last Post: 06-27-2008, 10:33 AM
