Thread: PCM not telling car to shift till later
Results 1 to 4 of 4
  1. #1 Re: PCM not telling car to shift till later
    Jul 2008
    nj
    When you reprogrammed the PCM, did you do a full rewrite? Is it only holding 3rd gear too long or all the gears?
    FOR SALE
    2003 GTP, L36 swap, TOGs extremes, ZZP stage 3 heads, SSIC, ZZP Ported Blower, 3.0/3.2 pulley, XP hot cam w/ 105#, 42.5# injectors, N* w/ 85mm MAF, Meziere Water Pump.
  2. #2 Re: PCM not telling car to shift till later
    Did you play with speed and rpm shifting tables? If so.. put the speed table to 0 and adjust the RPM to where you want the shift to occur. (I think that's what I've seen done).
    Otherwise you run the need to meet one/both criteria and that's what is likely giving you a hassle.
  1. Engine runs fine till temp starts to rise...
    By 97gpGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-24-2010, 11:22 AM
  2. won't shift out of first very well
    By melwil in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-05-2009, 01:07 AM
  3. GM should be telling all of us thanks.
    By 16MustangVet in forum General Tech Discussion
    Last Post: 06-04-2009, 10:53 PM
  4. shift kit
    By CHAMPS97 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2009, 09:27 PM
