Thread: Stage 2 axles?
Results 1 to 3 of 3
  1. #1 Stage 2 axles?
    GT Level Member glanzergtx's Avatar
    Dec 2008
    Sioux Falls,SD
    Are these axles worth it? I am going to be running a 3250 stall with DR's at the track with a full built trans. Will stock axles hold up? Or should i invest in the some upgraded axles?
    https://www.zzperformance.com/grand_...=858&catid=105
    The mods will be as follow
    CAM will be XP or bigger will be a winter project
    -ported inlet outlet s/c
    -ported LIM
    -ported heads
    - MPS 3.0
    -65# injectors for e85
    -Built trans with 3.29 gears 300mm input with 3250 stall
    -Drag radials
    -55 dry shot nitrous
    -Wizaird
    -1.9 rockers
    -TOGS
    -ported 97 TB
    -105# springs and retainers
    the axles on this car need to be replaced already. But is it worth the money for stage 2 axles if i dont need them?
    Just your normal 730whp 4dr family car.
  2. #2 Re: Stage 2 axles?
    stock axles are physically about the same strength. the good part about the stage 2 axles is that they have grease ports on them so you can actually regrease them when need be.
  3. #3 Re: Stage 2 axles?
    Dec 2008
    Sioux Falls,SD
    so for 300 bucks i get greasable axles whoohooo
  1. anyone breaking axles?
    By 99prixgt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-26-2009, 03:41 PM
  2. Don't buy these axles!!!!
    By 01RedfireGT in forum General Tech Discussion
    Last Post: 06-29-2009, 11:32 AM
  3. Axles
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2009, 09:59 PM
  4. Axles, hubs and Halos - oh my!
    By MnRedGP in forum General Tech Discussion
    Last Post: 02-08-2009, 02:08 PM
  5. Converter stall?Stock axles?
    By PWNED in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-14-2008, 11:51 AM
