Thread: Vibration from front end
Results 1 to 9 of 9
  1. #1 Vibration from front end
    Northern Vermont
    Hello,
    I just bought a nice 2000 GT as a dd two weeks ago. It's alot of car for the money, I must admit. 138k, no rust from Virginia, a long two days to get it and bring it back!
    So far, I installed two new yokohama AVID S tires on the front, forged solid front swaybar, new starter, halo projector headlights with HID xenons, bought an extra remote and chipkey all off fleabay and so far, aside from some LED problems on the headlight casings, everything went in good. Mostly this was maintenance work that the car needed.
    The biggest problem, of which I think is one of the half shafts.... Is that I am getting a vibration only going up hills and under slight acceleration on level surfaces, at between 45 and 75 mph. Under hard acceleration, it's gone. The vibration gets more intense when I go over a bump and the suspension compresses. The vibration was there before the new tires and after, so it's not the tires.
    I get no clicking with the old "hard slow turn in the parking lot test", so at first, I thought it wasn't a half shaft at all.
    How can I test more thoroughly, which, if any half shaft to see is going bad?
  2. #2 Re: Vibration from front end
    SE Level Member tpalmer's Avatar
    Florida
    Sounds like a cv axle to me. I had to replace my driver side one last spring. I had the same problems but I also had vibration when only turning right under acceleration. When I turned left under acceleration I didn't have any type of vibration. I replaced the driver side axle and the vibration went away, nice and smooth driving now.
    http://www.cardomain.com/ride/3307755
    ZZP 1.0 PCM | HV3 Insert | ZZP High Velocity Throttle Body | K&N FIPK Air Intake Kit | 2.5" DP | 2.5" Magnaflow Catback Exhaust | 180* T-Stat
  3. #3 Re: Vibration from front end
    Jul 2008
    sumter,south carolina
    my car did this when my downpipe was sitting on sway bar... could be a wheel bearing too. even struts.
    02 GTP with mods 05 GP for DD
  4. #4 Re: Vibration from front end
    Donating Users foursixer's Avatar
    boston,ma
    check the engine and transmission mount. they are hydraulic and collapsed when fail. this would cause vibration! post your final FINDING when fix
  5. #5 Re: Vibration from front end
    Northern Vermont
    Well after driving some on brand new tires, the problem has reduced but is not gone yet.
    No downpipe on my swaybar, so that is not it. I just pulled the sway bar and changed it to a forged design.
    I can see the motor mount on top, next to the radiator on top. It looks good and does not let the engine move much at all on a REV.
    I didn't even think about a transmission mount, never had even changed one in all of my years of tinkering. I will look around for it and see if it's toast!
    In the meantime I bought a locking gas cap and a spare blower motor, just in case that noise I am hearing coming from the blower turns out not to be a some leaves grinding against the blower cage.
  6. #6 Re: Vibration from front end
    boston,ma
    the mounts on top the radiator are the dog bones. the engine mount is on the passengerside of the motor below the crankshaft pulley. you can see it through the fenderwell behind the tire. you may have to move the plastic shield to get a good visual. the transmission mount is on the driverside just about the same location.
  7. #7 Re: Vibration from front end
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    check the tierods?
  8. #8 Re: Vibration from front end
    Northern Vermont
    Brand new tie rods just before I bought it, they are nice and tight.
    Hopefully I will get to looking at those engine and tranny mounts today.
    I tested the car through corners and under acceleration, between 30-50mph, and it vibrates in left AND right corners. Maybe I should be more biased towards the mounts rather than the CV's at this point?
  9. #9 Re: Vibration from front end
    Michigan
    well as long as all your control arms n sway bars are good[bushings included]..
    i'd say mounts. even at 140k you'll probably want to replace them.
  1. Those who are Lowered.....WOT front vibration
    By Trannyman95 in forum Brakes/Suspension/Chassis
    Last Post: 08-06-2015, 01:03 PM
  2. strange vibration from the front
    By Sandman in forum Brakes/Suspension/Chassis
    Last Post: 07-24-2009, 08:57 PM
  3. Please help, very bad vibration in front of car
    By tcestes in forum Brakes/Suspension/Chassis
    Last Post: 04-16-2009, 10:17 PM
  4. vibration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2008, 05:24 AM
  5. 01 GT Vibration in Front Right End
    By sweard2003 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-30-2008, 08:57 AM
