Thread: Repeated TCC lock/unlock with no PCS readout
Results 1 to 4 of 4
  1. #1 Repeated TCC lock/unlock with no PCS readout
    Feb 2008
    I put a used transmission into my car last week and have noticed that on the highway or anytime the torque converter is supposed to be locked, I get an oscillating lock/unlock at 10-15% throttle. More throttle keeps it unlocked, and less lets it stay locked.
    Upon scanning, I noticed that my PCS current was 0.00 A and the line pressure was frozen at 38%. Could I have a bad connection at the 20-pin plug, or could the PCS be completely dead?
    BTW, donor car supposedly drove perfectly fine, but blew head gasket and overheated (I helped tear the engine down). This was over a year ago.
  2. #2 Re: Repeated TCC lock/unlock with no PCS readout
    Feb 2008
    I really need some help with this one! It's driving me crazy.
    I did see that the PCS current was changing today, but the line pressure percentage was still stuck at 38%. I have a few scans if someone wants to take a look at them.
  3. #3 Re: Repeated TCC lock/unlock with no PCS readout
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    post um ,if your on the freeway what happens if you tap the brakes with your foot on the gas??
  4. #4 Re: Repeated TCC lock/unlock with no PCS readout
    Feb 2008
    The torque converter unlocks and stays unlocked if I touch the brakes while cruising.
    I'll post the scans here shortly.
  1. No lock/unlock but trunk release works
    By Twelvoltz in forum Audio, Security & Visual Electronics
    Last Post: 08-15-2009, 09:26 PM
  2. Tuner Changes for TCC Lock/Unlock Issue
    By Lawngoose in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2009, 10:42 AM
  3. Question: Tranny Torque Converter lock/unlock issue
    By Lawngoose in forum General Tech Discussion
    Last Post: 05-31-2009, 09:54 PM
  4. Increasing lock/unlock wirless strength
    By Freebeer187 in forum General Tech Discussion
    Last Post: 09-05-2008, 11:37 PM
  5. Trunk Switch/ Door Unlock and Lock
    By mainecrab in forum General Tech Discussion
    Last Post: 06-02-2008, 08:58 PM
