So...i was showing off again, and when i started a burnout the tranny clunked and the RPM's shot to redline. I now have no forward gears and no reverse...all = neutral! Is it an input shaft? The tranny is a fresh rebuild with a 1" chain, Intense 300M input shaft, 3250 convertor from ZZP, and 3.29 gears. I was told it was bullet proof, and certainly should be able to smoke the tires without issue when it's raining and the roads are wet! Any ideas what i broke to have no gears? There is no grinding, whinning, or fluid leakage, just all nuetral.
