Thread: tranny making noise
Results 1 to 7 of 7
  1. #1 tranny making noise
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    I am having a few probs. first off its a fully rebuilt tranny.
    ZZP Parts: 3.29s, 2500 stall, 4340 input, oil pump shaft, output shaft, 4th clutch shaft, shift kit, GM overhaul kit.
    thats what i brought into the transmission shop. They replaced alotta other things that were worn out as well. Valve bodies and other things i dont remember. Tranny originally had 193,XXX miles on it before rebuild.
    Got it on the road finally and heard a noise. I did almost everything to rule out the noise. Motor is fully rebuilt as well by the way. I had a P1374 code so i replaced the Crankshaft position sensor. while driving down the road when i let off the gas right away my rpms drop to bout 900 rpms. It definetly sounds like the transmission to me. But i just dont know what might be causing the noise im hearing. The noise is noticeable at around 2500 rpms and up. Im pretty sure its not a lifter(s) because i know i set preload properly before i put the motor back in.
    Im just at a loss. i dont know what to do anymore.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #2 Re: tranny making noise
    Banned - Busted For Scamming
    Feb 2009
    Vid?
  3. #3 Re: tranny making noise
    video doesnt justify. exhaust cancels the noise out from a videos aspect
  4. #4 Re: tranny making noise
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    discribe the noise
  5. #5 Re: tranny making noise
    like how if a coupler goes out on a supercharger almost. its not a knocking or ticking sound.
  6. #6 Re: tranny making noise
    Apr 2009
    stockton ca
    you shouldnt have to deal with these issues any more and should just give me your car...
    does it only make the noise while your driving
    At what speeds
    straight line or turning
  7. #7 Re: tranny making noise
    Feb 2010
    ohio
    convertor bolts loose??
  1. Ac compressor making noise
    By TorqueAutoMotiv in forum General Tech Discussion
    Last Post: 09-05-2010, 01:58 PM
  2. Suspension Making Noise in Cold Weather
    By anishtulsian in forum Brakes/Suspension/Chassis
    Last Post: 12-10-2009, 02:17 PM
  3. 98 GTP making noise by supercharger?
    By hunter_alexander in forum General Tech Discussion
    Last Post: 07-30-2009, 07:32 PM
  4. Engine making horrible noise.
    By starscr33m in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2009, 12:24 AM
  5. Brakes making noise.
    By TDCRacing in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2008, 10:03 AM
