Thread: trans going out?
Results 1 to 7 of 7
  1. #1 trans going out?
    El Paso, TX
    ok guys i have a 2006 base gp, recently when I put it in drive and step on the gas the car hessitates then goes foward I notice it kinda jumps and even on stop lights I step on the gas and it shudders a little bit. The first one sounds like a slipping problem to me and the second one sounds like motor mounts. I just need ideas and estimates lol, is there a way to tell how long my trans is gonna last me? I do a combination of normal and "spirited" driving but not anything crazy thanks for the help
  2. #2 Re: trans going out?
    El Paso, TX
    ok maybe im crazy or the problem is intermitten (cant spell) but it didnt happen today and I dont want to take it to the shop and they see nothing wrong but do nothing and risk the car leaving me somewhere cold and alone
  3. #3 Re: trans going out?
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    hows the fluid?? whats the milage?
  4. #4 Re: trans going out?
    El Paso, TX
    fluid is clear red... or im looking at the wrong dipstick and i just hit 60200 thanks for the reply btw
  5. #5 Re: trans going out?
    Feb 2010
    ohio
    hmm maybe a brooken tranz/motor mount, tranz fluid full?? with car in park car running at normal temp check the fluid see were its at to start with.no really telling wen a trans can go completly out out.
  6. #6 Re: trans going out?
    El Paso, TX
    hmmm well i'll recheck in the morning but it was driving and shifting fine today, and supposedly transmission codes dont set of the check engine light right? so maybe i can get it scanned
  7. #7 Re: trans going out?
    Feb 2010
    ohio
    u gota check fluid wen cars hot only way to check it acuretty, and trans does throw codes so if you get it scanned and there is a code make sure you write down code and info
  1. my new used trans
    By gtpinsc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2009, 05:11 PM
  2. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
  3. non-HD trans in 97 GTP?
    By BrokenRhythm in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-24-2008, 08:35 PM
  4. trans from l36,using a l67
    By srziemkowski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2008, 06:16 PM
  5. 06 trans in a 99 gt?
    By bronzemist99GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2008, 01:52 AM
