Thread: transgo shift kit install Q
Results 1 to 12 of 12
  1. #1 transgo shift kit install Q
    May 2008
    McHenry IL
    Hi guys i just got my shift kit from transgo threw dave at triple edge performance " HE IS THE MAN " anyways haha i got instructions with it but any tips and help i can use ill appreciate it thanks
  2. #2 Re: transgo shift kit install Q
    Jersey
    yeah, don't strip out the pan bolts, they're all aluminum
    why do u need to put it in? should have came assembled in the rebuild.
    16' wrx sti- stock
  3. #3 Re: transgo shift kit install Q
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Below is a link to a install write-up I did a while back
    http://www.grandprixforums.net/shift_kit.php
    Make sure you follow the extra instructions I wrote in with the instruction sheet!
  4. #4 Re: transgo shift kit install Q
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    take some GREEN scotchbrite and clean the bores of the accumulator before you install. Its recommended on transmission rebuilds. Just make sure you clean all debris when you reinstall it. The scotchbrite gives a place for the fluid to sit so the seal doesn't stick as the piston travels
    http://www.transtec.com/tech_insert/IS-4T65E-5.pdf
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  5. #5 Re: transgo shift kit install Q
    May 2008
    McHenry IL
    thanks dave a JJ the trans is sparkling clean right now used a TON of degreaser the case has never looked so nice in 10 years probably hahahaha and internals are sparkling 2 haha tomarrow starts rebuild. and thanks for the going the extra mile with the write up dave on the paper!
  6. #6 Re: transgo shift kit install Q
    GT Level Member 40th GP's Avatar
    Utah
    Quote Originally Posted by Trannyman95 View Post
    I know this is a way old thread and that this is off topic, but I keep seeing these write ups all around the board, and when I go there I get an error that the page is not there. Are the how-to pages going to be back online soon, or am I missing the info or updates on this? There are several other write ups I want to look at and none of them work for me.
  7. #7 Re: transgo shift kit install Q
  8. #8 Re: transgo shift kit install Q
    Utah
    That helps, but I am still curious about the how-to links not working. This one for example: http://www.grandprixforums.net/shift_kit.php takes me to a warning/error page, and several other links from other threads do the same thing. I noticed that it is all the links that end in .php. Is there a problem with the site or the links? Anyone know if they will be back online soon (I know they have been down for quite some time)? There are others that I would also like to follow but none of them work...I have tried searching and have not found a description of the issue or what the status is.
  9. #9 Re: transgo shift kit install Q
    The board is in the process of being updated when Rocket has time. Hopefully he can get to it..but meanwhile if you ask, we can refer you to other links that do work or do fresh writeups for you.
  10. #10 Re: transgo shift kit install Q
    Utah
    Cool, thanks. I am also wanting the one on repairing the windows found here: http://www.grandprixforums.net/window.php.
    Is there another way to access that or another write up of it?
  11. #11 Re: transgo shift kit install Q
    Repairing windows? You mean swapping a window regulator?
  12. #12 Re: transgo shift kit install Q
    Utah
    No, a fix for switches intermittently not working. The link I am looking for is from the first post in this thread: http://www.grandprixforums.net/repai...witch-109.html
  1. Those that have installed the transgo kit
    By Merlin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-14-2009, 11:54 PM
  2. what shift kit should i use.
    By 00pontiac1971 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2008, 09:06 PM
  3. Thrasher vs Transgo shift kit
    By anks106 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-03-2008, 10:21 PM
  4. Getting a shift kit
    By ryangtp89 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2008, 10:20 PM
  5. easiest shift kit to install ?
    By bayareagtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-26-2008, 09:18 AM
