Thread: Transmission fluid leaking into radiator.
Results 1 to 5 of 5
  1. #1 Transmission fluid leaking into radiator.
    Feb 2010
    Virginia
    I have just discovered that the transmission fluid is leaking into the radiator. So my first thought is to replace the radiator and flush out the transmission fluid. But i am not sure if the coolent has enetered the transmisson. I am wondering if anyone has any suggestions what i am up against. Thanks
  2. #2 Re: Transmission fluid leaking into radiator.
    Feb 2010
    Virginia
    Quote Originally Posted by Fatboy58 View Post
    Also, Is there a Transmission cooler on the car or is it with the radiator...I am getting confused.
  3. #3 Re: Transmission fluid leaking into radiator.
    SE Level Member COEBAM's Avatar
    LAWRENCE KS
    You need a new radiator. Yes there is a built in trans cooler in the radiator. Sometimes they rupture. The bigger concern is there is no coolant in the trans fluid.
  4. #4 Re: Transmission fluid leaking into radiator.
    GXP Level Member Zef_66's Avatar
    PA
    If you just caught it, then there is a good change that no coolant got in the tranny. But check the color and condition of the tranny fluid to be sure. And whatever you do, do not drive the car at all. In fact, do not even start the car! Replace the radiator, flush the coolant out, replace with new, drop the pan on the transmission, put in new filter and new fluid. Then have the trans flushed as soon as possible afterwards.
    2001 GSE
  5. #5 Re: Transmission fluid leaking into radiator.
    GT Level Member Z28's Avatar
    Oct 2008
    Omaha, NE
    Quote Originally Posted by Zef_66 View Post
    I could not agree more, do exactly this.
    This happened on my camaro.
  1. transmission lines leaking
    By Orbital431 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-12-2009, 12:31 AM
  2. 98 GTP leaking tranny fluid
    By millfire517 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-28-2009, 11:02 AM
  3. Leaking tranny fluid
    By c002529 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-24-2009, 07:00 AM
  4. Help!! Tranny leaking fluid
    By NMillis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-12-2009, 06:48 AM
  5. Fluid Leaking out of Axle Seal Still
    By Metallistar in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 04:39 PM
