Thread: GTP Tranny Noise, Need Help
Results 1 to 14 of 14
  1. #1 Re: GTP Tranny Noise, Need Help
    Oklahoma
    A little play in the CV shaft is normal. As for the whine, I'll defer to trannyman and his input as he is far better qualified to answer that than I am.
  2. #2 Re: GTP Tranny Noise, Need Help
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    The whine noise can stem to numorous areas of the transmission and there are a few very common ones. I need to know when exactly this noise is present.... Does it make noise sitting still in Park? Neutral? In gear NOT moving? Stalling up the engine in gear not moving? Only when moving? Only in certain gears or speed? The more info I have the easier it is to pinpoint your concern. I have often heard an idler pulley bearing make a noise that distinctly says trans, but is not and using a stethoscope to rule that out helps so you can listen to all of the accessories on the front of the engine or even put it on the trans itself if it does make noise with the car sitting still. An easy test is simply to remove the engine belt/belts if supercharged and see if the noise is still present. If you can answer the above questions as to when this noise occurs I can help out further
  3. #3 Re: GTP Tranny Noise, Need Help
    SE Level Member GTPGP98's Avatar
    NorthEast Kansas
    Thanks for the response guys. The noise is not present when it is in Park or Neutral, but is constantly present throughout speeds from 5-75 MPH, I am sure that it is present at higher speeds but that is above our speed limit here. I just replaced all of the idler pulleys last summer, but I will remove the belts today and try that just to rule those out. What are the common areas of the tranmission that cause noise?
  1. Humming Noise During Acceleration
    By Burgundyman in forum Brakes/Suspension/Chassis
    Last Post: 01-02-2010, 10:03 AM
  2. Loud whistling noise
    By Minno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2009, 09:04 PM
  3. Whats this noise? (Video)
    Last Post: 02-27-2008, 02:05 AM
  4. Tranny Man
    By 19SE92 in forum 1984-early 1990's 4 Speed Automatic (440T4)(4T60)
    Last Post: 02-15-2008, 11:38 PM
  5. tranny
    By bad1999gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-07-2008, 02:04 PM
