Hello all,
As the weather got colder up here i noticed a few problems with my transmission. Initially, it has trouble shifting from 2nd-3rd under low throttle - typically this happens when i'm rolling along at about 60km/hr and giving it just a little bit of gas. The car will quickly jump in RPM's a couple hundred and it seems like there is not enough trans pressure to complete the shift.
The other issue i have is when driving full thottle, the car cannot make the 3rd to 4th shift (It seems to be unable to make the shift when approaching redline). Under lower RPM i can get into 4th gear no problem. EDIT: Could possibly be the 2nd-3rd shift again. The shift occurs when driving WOT at about ~150km/hr.
Anyone have any insight into these problems? Aside from these issues it shifts firmly and behaves normally. They seem to have come with the cold weather.
Thanks
