Thread: Transmission is detroyed?
Results 1 to 11 of 11
  1. #1 Re: Transmission is detroyed?
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    My initial thought was a bad cv but since you later mentioned replacing them that rules them out as long as they were all checked to be ok or replaced. If your differential is coming apart that will definately cause the problems you have going on and if that checks fine then you likely have some internal geartrain damage
  2. #2 Re: Transmission is detroyed?
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by Trannyman95 View Post
    x2
    My bet is... unfortunately, a issue with a drive sprocket. I once had this exact problem with my car and that is what it turned out to be.
  1. Transmission
    By joeyt637 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-04-2009, 11:22 AM
  2. transmission
    Last Post: 09-02-2009, 11:14 AM
  3. PCM, transmission lag?
    By dagger in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-14-2009, 09:41 AM
  4. transmission ??
    By french080 in forum General Tech Discussion
    Last Post: 01-18-2009, 03:38 PM
