Thread: Driver side halfshaft problem
Results 1 to 11 of 11
  1. #1 Driver side halfshaft problem
    Jul 2008
    Indianapolis
    I can't get it out!! Simple as that.
    I gave the whole shaft a good tug and it separated at the inner boot and now the piece that attaches to the differential will not come off. Should it have been this hard to get off?
    Any ideas on how to get that last piece out of the diff?
    Everyone seems to have issues getting the new one back in but not taking the old one out so I'm stumped.
    Any help would be appreciated. Headed out to work so I'll tackle this when I get home tonight.
    BTW: Its a 2000 GP SE with 3.8
  2. #2 Re: Driver side halfshaft problem
    Donating Users ninnyGTP's Avatar
    Nov 2008
    Moreno Valley, California
    You're going to need more than a good tug to remove an axle.. Pickle fork man! haha
    98 Grand Prix GTP L32, GenV, n*, 3.2", 1.9 rr's, 3.29 gears. All that jazz SOLD
    99 Mustang GT Steeda UDPs, 3.73s, Pypes O/R xpipe, Accufab plenum, Steeda CAI, B&M ripper, MHS s2 cams, 10.5:1 compression (290whp/310wtq) SOLD
    01 SVT Cobra #3654, B&M Ripper, K&N FIPK2, MAC O/R xpipe
  3. #3 Re: Driver side halfshaft problem
    PA
    Yeah, you can't just pull on the driveshaft or it will separate like yours did.
    But to get it out, you need to get a prybar inbetween the driveshaft and the transmission case. Don't pry too hard or you can crack the tranny case. But a good, quick, stout push from a pry bar should pop it out. There is a snap ring on the driveshaft that you have to compress to get the axle out. So the quick pressure compresses it enough to pop out.
    2001 GSE
  4. #4 Re: Driver side halfshaft problem
    Aug 2008
    Long Island, New York
    either this or you can try taking a mini sledge and an 8 inch extension and TAP it out, dont hit it too hard though
  5. #5 Re: Driver side halfshaft problem
    Jan 1970
    Maquoketa, Iowa
    Sometimes a good yank with the hands will get it out. Sometimes a prybar and tap the shaft with a hammer will be enough.
  6. #6 Re: Driver side halfshaft problem
    PA
    I have also heard of people using slide hammers. But I don't have one and never used one. So can't say for sure how well they work. But just a thought.
    2001 GSE
  7. #7 Re: Driver side halfshaft problem
    Jul 2008
    Indianapolis
    well....the consensus seems to be to use some good ole muscle and a construction tool!! I'll give er a shot and hope that all goes well without any more things breaking.
    Thanks for all the advice.
  8. #8 Re: Driver side halfshaft problem
    Aug 2008
    Quote Originally Posted by green00prix View Post
    remember dont hit it too hard. and also, if you see the thin output shaft comin out with it, stop!
  9. #9 Re: Driver side halfshaft problem
    Jul 2008
    Indianapolis
    Got er out with a lot of work. Never had a halfshaft be that difficult. Crow bar and a 4lb sledge took care of it after a while.
  10. #10 Re: Driver side halfshaft problem
    Apr 2009
    stockton ca
    WHEn i did my trans i used the slide hammer method to pop the cv's out both were out with 5 min
    If your having problems getting it out id reccomend checking your local autozone and see if they have one to rent out
  11. #11 Re: Driver side halfshaft problem
    Moore, Oklahoma
    Slide Hammer FTW! The only way to do it IMO. Autozone has the CV puller/Slide Hammer for rental....
    Shawn W. Larsen
  1. Vibration driver side, how to fix?
    By gmoney25 in forum General Tech Discussion
    Last Post: 09-25-2009, 09:31 AM
  2. '04 Driver Side Air Vents
    By Sabreslight in forum General Tech Discussion
    Last Post: 07-11-2009, 12:41 AM
  3. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
  4. Driver's side axle / halfshaft issue...
    By GrandPrixGT300 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-19-2009, 04:00 PM
