Thread: Transmission Code and no 4th gear HELP
Results 1 to 6 of 6
  1. #1 Re: Transmission Code and no 4th gear HELP
    GT Level Member Gregorius's Avatar
    Davenport, IA
    Yeah, no.
    It's rebuild time. No band-aid will make things better. The solenoid probably isn't "bad", but full of crud. Like the rest of the trans is. I would guess the frictions were shot, which started the initial slipping. Lucasing it just stopped the slipping for a while, but didn't address the issue, and now all the shot clutch material is happily clogging the trans to death...like the solenoids... I just got done rebuilding mine, and it was a Complete PITA.
    Have Dave at Triple ship you a new one.
    Dude! Full Service Manuals! 2004-'08 User manuals, full docs wiring diagrams trouble codes... go look.
    WarStryker13's Google drive
    ... our lady of blessed exceleration, don't fail me now ...
  2. #2 Re: Transmission Code and no 4th gear HELP
    I've found great info using Gearchatter.com and searching the codes. They have the FSM's online basically.
    A soleniod isn't that bad to replace, but it does require dropping the cradle enough to get the side cover off.
  3. #3 Re: Transmission Code and no 4th gear HELP
    fall river mass
    yeah I dont think I have to change the tranny just yet because I heard I can replace the shift solenoid and it will be fine cause after the filter change and fluid change my tranny never slips not once shifts mint its just this solenoid thing right now. I get every gear except four which is why I dont get it and also sometimes it will start out in 2nd its kinda weird but shifts fine like doesnt slip... autozone sells a shift solenoid which is 28.99 I was wondering if anyone can help me locate it cause I have no idea where it is. If someone can give me a diagram or tell me where to look id really appreciate it. Because Im gonna change that first before I change my tranny... I also got fourth gear today it started working fine like shifting fourth but sometimes it wont. I was thinking when the tranny fluid gets really hot its works fine cause the lucas is too thick and clogging the solenoid so again if anyone knows where it is id appreciate some help thanks alot, Nick
    here is the link to the solenoid I think I have to replace
    http://www.autozone.com/autozone/cat...dName=Duralast
  1. top gear
    By 1999gt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-07-2009, 08:54 PM
  2. Transmission slipping/hunting for gear?
    By The Chad in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-01-2009, 11:44 AM
  3. First gear studders
    By stoner17971 in forum General Tech Discussion
    Last Post: 06-25-2009, 11:22 AM
  4. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
