Thread: Have a 4T65E Question? Please Read! Triple Edge contact info
Results 1 to 20 of 67
  1. #1 Re: Have a 4T65E Question? Please Read! Triple Edge contact info
    The Boss Iceman6669's Avatar
    Jun 2011
    The only problem my tranny has is when I am in OD going about 55-60 and start to go up hill and give it a little bit of gas, NOT enough to make it downshift just enough to let it maintain speed, my tranny appears to slip. My RPM's just from about 1.5k to 2.5k... Some one on here had said it might be a plug/wire/coil problem. Is that true? My tranny has 225k on it....
  2. #2 Re: Have a 4T65E Question? Please Read! Triple Edge contact info
    Quote Originally Posted by Iceman6669 View Post
    1000 rpm sure sounds like it's downshifting. It might be plugs/wires. You know..we will be sarcastic..but we won't intentionally like to you.
  3. #3 Re: Have a 4T65E Question? Please Read! Triple Edge contact info
    PA
    If the RPMs are jumping up and down, it could be a TCC or valve body issue.
    TCC rpm oscillation
    2001 GSE
  4. #4 Re: Have a 4T65E Question? Please Read! Triple Edge contact info
    Jul 2011
    United States
    I'm having the same issue with my GTP. It has 162,000 miles on it. The RPMs don't jump when I'm accelerating but it jerks like it can't decide whether or not to downshift. If I step into it, it down shifts and does fine. It has felt like it slipped twice when starting from a stop too. No SES light. Once in a while I get a ABS light or TC Off but I'm pretty sure that's a separate issue. Have you had any luck getting it fixed?? I've heard it could be a PCM problem, TCC solenoid, plugs, wires, coils, or the transmission going bad.
  1. 4T65E Tech Manuals available from Triple Edge Performance!
    By Trannyman95 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-17-2015, 08:53 AM
  2. thank you again triple edge performance
    By nemesis in forum Shops and Community Heroes
    Last Post: 01-28-2009, 01:00 AM
