One other thing, I get a check engine light every time I flash the car....but theirs no code ever so I clear it...?
^^No, after a flash and you cycle the key and start the car, the check engine light goes on
Are you still using the original/ correct pcm for the car? I know DHP allows flashing different year pcms that dont have the correct OS / year match but they will work and sometimes have side effects. Are you checking the code with your DHP or an actual scan tool? Often there are other codes that arent supported by the tuners and only a full scan tool will say what is going on.
Yea, it's the original pcm that cam with the car. I've tried checking the code with DHP but nothing shows...says "no codes found". Never tried a scan tool before. I figured it's probably a flashing glitch since it never caused a issue that I've seen...could be a bcm or bus controller code i guess. But after clear the code it never shows again till I reflash again.
