Thread: Need some help
Results 1 to 12 of 12
  1. #1 Re: Need some help
    Destroys cars izup69's Avatar
    Iowa
    sounds like u got a decent deal on the car if its only under hard acc check fluid make shure its full and see if its clean (not dark red or black) if it is id say change fluid filter and check for clutch matiral/mettal shaveins in pan if none should be find see if it helps maby not gettin enuf press cuz filter cloged if ur lookin for good tranys Trannyman95 on here is your best bet he builds great trans go look for urself
    Triple Edge Performance - Home Page
  2. #2 Re: Need some help
    fall river mass
    Hey man thanks alot for the advice, I changed the tranny filter and added new fluid with some lucas and now the tranny doesn't slip. The only thing it still does sometimes is when I punch it goin from 3rd to 4th it like bounces rev limiter and doesnt go to 4th unless I let off a little. 4th is like the only gear it shifts kinda weird but all the others are mint. I also checked the check engine light that came up and it said like torque converter stuck on and shift selinoid which im confused about cause its fine now so does that mean eventually its gonna go and im just good for now ? Also I have a regal gs can I use the shift selinoid from that tranny ? and are the regal gs trannys the same as gtps
    thanks, Nick
