Thread: 2006, Transmission Doing Odd Things
Results 1 to 2 of 2
  1. #1 2006, Transmission Doing Odd Things
    West Virginia
    Greetings,
    The transmission in my 06 Grad Prix started doing a couple funny things a couple months ago. First I was on a fairly long trip on a hot day and I noticed the tranny shifting hard into 3rd gear. It did this for a short while, an hour or so, and then the problem went away. The tranny then acted fine for a month or so and then on another trip, not nearly as long, I noticed it didn't want to shift into OD. Then on another short trip it would shift into OD but then kick back down into a lower gear on a slight pull. That was not normal. Anyway, it does these things at any given time and then it will be fine for a while. Any ideas? Thanks for the help.
    Bohunter.....
    One more thing, the check engine light did come on during at least one of the instances so I took it to a local shop today and they say the failure code indicated a problem with a speed sensor in the transmission. What will I get into if this is the problem? Thanks again......
  2. #2 Re: 2006, Transmission Doing Odd Things
    Banned - Busted For Scamming
    Feb 2009
    Youre going to have to tear the side cover off and replace it then, the input speed sensor.
  1. got a couple new things done with my car
    By CMURDAx in forum Visual/Body Modifications
    Last Post: 08-05-2009, 11:46 PM
  2. A Few Things For Everyone To Read
    Last Post: 12-07-2008, 01:18 AM
  3. 3 things yall should do...
    By gpchris in forum Forum Bugs/Suggestions
    Last Post: 12-27-2007, 10:24 AM
