Thread: PCM = hard shifts. normal?
Results 1 to 4 of 4
  1. #1 PCM = hard shifts. normal?
    GT Level Member flash527's Avatar
    Indianapolis, IN
    I installed my Intense pcm a couple days ago, and I noticed that my car is shifting very hard regardless of throttle position. also, on the freeway, if i let off the gas and coast, the car shifts out of OD into third, then as soon as I press the gas again to maintain speed, itll shift back into OD very rough. is this normal?? thanks guys
    04 GTP - FOTB, Intense PCM, 180* Thermo, SLP Headers, 3.4" ZZP Modular Pulley, Moroso Race Wires, 104 Plugs, TEP trans: 3.29's, Thrasher shift kit. Soon to come: 13 inch dual piston brakes, rims and tires, wideband tune by PRJ.
  2. #2 Re: PCM = hard shifts. normal?
    Jan 1970
    Maquoketa, Iowa
    Sometimes a change in the pcm trans settings will take a while for the car to get used to, or for you to get used to. I would drive it another day and see if the issue persists, but from the sounds of it, it is not supposed to be shifting to 3rd while coasting...
  3. #3 Re: PCM = hard shifts. normal?
    Donating Users chrisb's Avatar
    Bucyrus, OH
    yeah the intense one has several paramters changed. like said above it takes a bit for the "adaptive learning" to learn how you drive. It might take a week or more of driving for it to calm down a bit. mine would slip in gear and sucked at shifting at first but after i think 2 weeks it would shift just right at wot and around town. And the shifts are going to be harder and quicker.
    ill have to see if mine does the same thing or not with it going out of od like that whats the speed it does that at?
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  4. #4 Re: PCM = hard shifts. normal?
    Indianapolis, IN
    pretty much anytime i'm in overdrive itll do it. but usually on the interstate im goin about 70 or so. i have noticed sometimes it doesnt shift hard. for the first 10 minutes or so its really smooth but seems to get worse the longer i drive. wierd.
  1. car only shifts when it wants to??
    By orange97gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2009, 04:06 PM
  2. Hard Shifts.
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-11-2009, 09:18 PM
  3. my car shifts very hard when i put it in reverse
    By volsgirl in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-10-2008, 04:02 PM
  4. Trany shifts Hard down but easy up
    By jacobmh27 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-29-2008, 12:03 PM
  5. Shifts are pretty hard...
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-18-2008, 11:13 AM
