Thread: Hayden trans cooler?
Results 1 to 7 of 7
  1. #1 Hayden trans cooler?
    Jersey
    Like the title says im thinking about getting one, If tranny man sells them then they must be good? Does it bypass the one in the radiator? I would want a trans cooler that uses both? is that possible? Reason i want one is because its been getting really hott here. I was driving around on Sunday which was like 100* and i noticed my trans temps were climbing, then i was merging onto an on-ramp and it hesitated then slipped on the downshift from 3rd to 2nd a little. I thought i might need a new trans but then i checked the fluid which was bright red but just boiling, lots o bubbles on the dip-stick. I tried ripping around at night when the temps dropped and i had no problems. I did get an over sized radiator because i thought it would keep the trans cool enough...
    16' wrx sti- stock
  2. #2 Re: Hayden trans cooler?
    Just wondering if you have done a pan drop and filter change recently? If not get on that fasho!! Get some Dexron VI to replace the Dexron IV that is in there...and if you ain't got one...get a shift kit too from Dave...TransGo FTW!! Can't really give ya anymore insight on the cooler as I only have a stock...well...everything there. Honestly...I'd ask the source...see what Dave thinks
  3. #3 Re: Hayden trans cooler?
    Banned - Busted For Scamming
    Feb 2009
    you can do a supplemental cooler no problem. the police impalas came with them as well as oil coolers from the factory. if i see another one, im yankin the oil cooler stuff
  4. #4 Re: Hayden trans cooler?
    Barksdale AFB, LA
    You don't want one that uses the built-in trans cooler to the radiator. The hot coolant in the radiator will only heat up the trans fluid even more. Get a stand alone cooler since that will yield you the best performance.
    2009 Subaru Impreza WRX STI
  5. #5 Re: Hayden trans cooler?
    Feb 2009
    make sure and use good fittings, not that clamp on rubber hose bs, thats asking for failure
  6. #6 Re: Hayden trans cooler?
    Jersey
    thanks guys for all the replies. I have an intense shift kit in my tranny along with amsoil tranny fluid and gm filter. What kinda cooler does everyone else use? I wanna be sure i get a really good one.
    16' wrx sti- stock
  7. #7 Re: Hayden trans cooler?
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    Or you can buy a OEM GM trans cooler made specifically for the wbody cars, which was an option at the dealership.
    This is one of the best prices I've seen for this kit.
    Auxiliary Transmission Cooler Kit - W-body - PFYC
    Directions here
    1995-1999 W Transmission Auxiliary Oil Cooler (KD1) Project
    This is probably the one I'm going to get, although I'm looking into a bar/plate standalone cooler but I'm not sure if its worth the cost.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  1. trans cooler line leaking
    By _nick_ in forum General Tech Discussion
    Last Post: 09-21-2011, 09:58 AM
  2. bypass rad cooler?
    By _nick_ in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-25-2008, 02:10 PM
  3. Trans cooler lines, which is IN and which is OUT?
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-30-2008, 11:45 AM
  4. GM aux trans cooler
    By 07 GPGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-25-2008, 09:32 AM
