Thread: Transmission Overdrive Problem
Results 1 to 3 of 3
  1. #1 Transmission Overdrive Problem
    GT Level Member Egleone6's Avatar
    Springfield, Illinois, United States
    I just noticed here lately, that whenever I drive, my car does not want to go into 4th gear. We were driving home yesterday, and it was cold and wet, and just for a second, we noticed that the car jumped like it had came across a black ice. Ever since, it has not gone past 3rd gear.
    I was told it could be a speed sensor or the cellinoid sensor getting worse.
    I flushed the tranny fluid last summer and when the car gets hot, it switches into what has been told to me is, "fail safe mode".
    Any ideas?
    If my pics are not working, please email me, I may have moved the pics on a different page on Photobucket. Thanks
  2. #2 Re: Transmission Overdrive Problem
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    We need your car info to help you out, what Year/Make/Model vehicle do you have? How many miles are on it? If it is an 02 or earlier than you likely have a stripped 4th clutch shaft which is very common to see. The best way to verify this is to have the car diagnosed with a scan tool and watch to see if the pcm is commanding the car to shift into 4th. If it is commanding 4th and wont physically happen it will generally not throw a trouble code. Typically any trans limp-mode type condition will go away with a key cycle and work as it should until the pcm sees a problem, but if it is a mechanical problem it will continue to exist after a key cycle such as a bad 4th clutch shaft.
  3. #3 Re: Transmission Overdrive Problem
    It is a 2001 GP GT. 90K miles. If it is a stripped 4th clutch shaft, how difficult is that to change, hours?
    I am going to a tranny shop, I will see what code it gives me.
    Thanks for the info.
  1. 95 grand prix se transmission problem
    By grandprix95 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 01-13-2009, 01:39 AM
  2. Transmission help.
    By RichCresci in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-03-2008, 03:35 PM
  3. Transmission=Done
    By SLO-6 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-30-2008, 01:58 AM
  4. Overdrive Problem (does not seem to be one)
    By jacobmh27 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-14-2008, 10:02 AM
