Thread: Changing fluid, geting it all out
Results 1 to 16 of 16
  1. #1 Changing fluid, geting it all out
    CT
    I want to change my transmission fluid this weekend along with installing my shift kit but I'd like to get as much of the old fluid out as possible. I've read a few different ways of doing this. Anyone know a good way to do this? I read about putting a tube down the dip stick and sphining it out but heard it could take over night to get it all out then. Which I don't mind, I'll start friday night if need be.
  2. #2 Re: Changing fluid, geting it all out
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    youll never get it ALL out, unless you drop the trans.
    Id just do the filter gasket when you do your shift kit then get it flushed, or do the fliter/gasket/fluid then the shift kit, this way the filter and fluid are all new, get a new filter and 6 qts of fluid( maybe less) and youll be set. I found this way to ensure a near complete fluid change.
    How many miles are on the car/trans?
  3. #3 Re: Changing fluid, geting it all out
    CT
    73,000 on it. I was planning on just dropping the pan then doing the shift kit, then put the filter on and put the pan back on with a new gasket then filling it back up with dexron 6
  4. #4 Re: Changing fluid, geting it all out
    SE Level Member GTP2K1's Avatar
    Tampa, FL
    Quote Originally Posted by WhiteDevil View Post
    6qts? I thought it was 8-10 for a pan drop.
    Cheap, Fast, Reliable... you can only pick two
    http://www.cnfcgp.com/
  5. #5 Re: Changing fluid, geting it all out
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Installing a shift kit definately means losing more fluid so I would plan on replacing at least 8 quarts, total capacity is roughly 13 but a lot will remain in the torque converter and the only way to get it all out is having a trans flush. IF you want to get creative and do it yourself you can start up the car with the feed cooler line unhooked from the radiator and sitting in a large drain pan- there is about 20-40 psi here so make sure the line is support and it will drain fast! IMMEDIATELY after you see the fluid quit coming out shut the engine off and dump 6 quarts back into the trans and do it again. Repeat this until the fluid looks like new coming out of the tube. Generally flushing a trans takes about 12-25 quarts depending on how bad the fluid looks and if it looks bad to start with then a complete flush is not the best thing to do, there is info on my website info page of why.
  6. #6 Re: Changing fluid, geting it all out
    CT
    Quote Originally Posted by Trannyman95 View Post
    Thanks a lot, I'll give that a try. I'd rather not spend money on new fluid then go out and pay $180 for a full flush. I'll let you know how it goes.
  7. #7 Re: Changing fluid, geting it all out
    Fort Wayne, IN
    I will just warn you to be prepared for a mess so USE CAUTION!!!! If you dont have trans flood all over the floor when you are done pat yourself on the back and slug down a cold one!
  8. #8 Re: Changing fluid, geting it all out
    Barksdale AFB, LA
    It's no big deal to have to get all the old fluid out. Putting a tube down the dipstick will do nothing more dropping the pan.
    2009 Subaru Impreza WRX STI
  9. #9 Re: Changing fluid, geting it all out
    Aug 2008
    60118 NE Illinois
    Im not sure what these tranny's take, didnt figure their pan capacity was bigger then a rwd th unit.
  10. #10 Re: Changing fluid, geting it all out
    CT
    I get to do it on the lawn so I'll have to find a way of covering all of it so no animals get at it. I'll let you all know how it goes.
  11. #11 Re: Changing fluid, geting it all out
    Aug 2008
    60118 NE Illinois
    I made a 3'x3' box a long time ago, had about 100 pounds of cat **** litter in it w/ a fine mesh reinforced screen about 1" down from the top of the box, saved so much time cleaning and no missing or "lost" bolts in the drain pan. Also, tranny fluid is not harmful in moderation to humans or animals( makes em wet **** alot) however its the anti-freeze and mainly the green kind thats toxic, im not sure on the dex-cruel ****.
  12. #12 Re: Changing fluid, geting it all out
    CT
    yeah but my dogs a retard, he'd eat it all up.
  13. #13 Re: Changing fluid, geting it all out
    CT
    alright, another question. I don't want to start a new tread as its kind of along the lines....sort of. I got a shift kit. I'm just trying to figure out exactly how much of shim I should install for my shifts. I have (1) 1/4", (1) 1/2", (3) 3.4" and (1) 1". they recommend the 1/2 on the 1-2 shift, and 3/4 on the 3-4 shift. I want something that I'm going to notice a difference in shifts. I don't want it to seem like its just quicker. I don't need tire chirping as I figure that will hurt the trans but it would be nice.
  14. #14 Re: Changing fluid, geting it all out
    May 2008
    McHenry IL
    lmao im with you brother in the summer im going to get a trans kit and change my fluid and filter etc... i got 131 on the clock and i got it at 123k so i def need to change the filter "NOT TRYING TO STEAL YOUR THREAD" but what is a safe way to do this work insuring the trans wont slip and stuff. i hear bad sotries...
  15. #15 Re: Changing fluid, geting it all out
    i thought u guys don't recommened flushing the trans?
  16. #16 Re: Changing fluid, geting it all out
    CT
    well did it sunday, went great. Shift kit works fine. Not as much as a difference as I would have thought but I think with a new PCM and the raised shift line pressure that it will be rather nice. Shifts are much firmer though and it feels an overall smoother.
  1. changing fluid and filter in tranny???
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 07-23-2012, 06:06 AM
  2. changing over to a new oil need opinons please
    Last Post: 06-01-2009, 12:46 AM
  3. changing to a l67
    By srziemkowski in forum Off Topic Discussion
    Last Post: 02-10-2009, 09:44 PM
  4. Thinking of changing oil
    By GTP4 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2008, 04:00 PM
  5. Changing headlights
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 02-26-2008, 08:56 PM
