Thread: Tranny Differnces: HELP!
Results 1 to 4 of 4
  1. #1 Tranny Differnces: HELP!
    SE Level Member nathangartz's Avatar
    Nov 2008
    Milwaukee
    Hey all,
    I just pulled a engine and trans out of a 97 GT. I had a donor engine and trans that I was told would work in it and it was cheap so I picked it up. HOWEVER....just before I was about to drop the donor trans in, I looked at the plugs and realized they are different.
    Here is the plug from the original that was in the 97:
    And here is the plug from the trans that I bought:
    The reason why I want to put a new trans in is because the old trans has over 200,000 miles on it and the new one has only 80,000. I just can't see any way in getting the new trans in there since they seem so different. Has anyone else had the same problem? The plug is actually in a physically different location as well. If you were in front of the car, looking strait down at the original trans, the plug would be coming straight at you. The donor trans has the plug coming out the side.
    I actually have three transmissions currently (plus the original 97 trans with 200K on it). I have two trannies with this plug pattern:
    The one I planned on being the donor:
    And the original with 200K on it:
    Can you identify them for me? What will each one work in? Am I stuck with having to deal with the 200K motor since the other three are different plugs?
  2. #2 Re: Tranny Differnces: HELP!
    Barksdale AFB, LA
    A 97GT has a 4T60E. Not a 4T65E. It'd take some work to do the conversion.
    I can't identify them for sure from the plugs, but it looks like the other two you have are a pre-03 4T65E and a post-03 4T65E.
    It'd be a lot easier to identify them if you could tell us what they came out of. There's more than the plugs that is different (like gear ratios).
    2009 Subaru Impreza WRX STI
  3. #3 Re: Tranny Differnces: HELP!
    http://i16.photobucket.com/albums/b3...z/IMG_2729.jpg
    Appears to be a 97/98 4t65e
    http://i16.photobucket.com/albums/b3...z/IMG_2728.jpg
    Appears to be a pre-03 4t65e (2001/2002)
  4. #4 Re: Tranny Differnces: HELP!
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    iirc, there are 3 different number of pins for the 4T65E. Mine's a 99 Buick LeSabre, 2.86 FDR with 14 pins.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  1. what tranny will fit in a 98 gtp ?
    By 98gtp1000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-04-2009, 08:49 PM
  2. 9C1 Tranny Help
    By cobraz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-25-2008, 11:36 PM
  3. What tranny comes with my car?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-23-2008, 11:36 AM
  4. 9C1 Tranny Help
    By cobraz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-22-2008, 08:51 PM
  5. 3rd Tranny!
    By offroadfury6 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-21-2008, 12:02 PM
