Thread: trannyman can u help
Results 1 to 20 of 20
  1. #1 trannyman can u help
    Feb 2009
    lima ohio
    hello my name is joe live in lima ohio i have 1997 pontiac grand prix gt 3.8 liter 130,ooo on car its started to not shift from 2-3 unless i back off gas i changed filter& fluid no metal residue in pan i had codes n at auto zone and nothing came back about tranny jus about misfire and vaccunm?
  2. #2 Re: trannyman can u help
    GTP Level Member Scimmia's Avatar
    QCA, IA
    97 GT is going to be a vacuum controlled trans, what vacuum code did you have?
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: trannyman can u help
    Feb 2009
    lima ohio
    i dont know ill check and be right back thanks
  4. #4 Re: trannyman can u help
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    If the car has a bad misfire it will not want to shift likely until you lift throttle as the pcm sees a greater load than it should and letting off the gas puts less load on the engine so it will allow the shift. Have you inspected plug wires, spark plugs, coil pack terminals? How does the engine itself run? Once it shifts into 3rd gear can you accelerate smoothly or does it feel like there is a power loss?
  5. #5 Re: trannyman can u help
    Feb 2009
    lima ohio
    code po 441 and code po 300
  6. #6 Re: trannyman can u help
    QCA, IA
    Ok, P0441 is for the EVAP, so I don't see that affecting the trans shifting. P0300 is random misfires, though, you need to get that one figured out. Being random, unfortunately, it's probably not the plugs/wires/coil packs as Dave mentioned.
  7. #7 Re: trannyman can u help
    Feb 2009
    lima ohio
    so it sounds as my tranny is shot i just ran to store and it wouldnt shift out of second
  8. #8 Re: trannyman can u help
    Fort Wayne, IN
    Why do you say this? I have done drivability testing and repair for a long time and ANY ignition problem can trigger this code, it isnt always a specific cylinder code that will set.
  9. #9 Re: trannyman can u help
    QCA, IA
    If I'm wrong, I'm wrong, but if it really is random/multiple, I don't see how a single bad plug or wire could cause it. First step would be to hook up a scan tool and watch the misfire counts, see just where it's happening.
  10. #10 Re: trannyman can u help
    Jan 2009
    Tallahassee, FL
    A misfire could be any ignition component. I has a random misfire because of a bad plug, then again none of them were changed ever when I got the car.
  11. #11 Re: trannyman can u help
    Fort Wayne, IN
    Code P0300 can occur from several things but the easiest things to rule out first are the secondary ignition components ie the plug wires, spark plugs, and commonly corroded ignition coil plug wire ternimals. I have also ran into many bad coils that appear fine and arc internally. Some things are hard to see and without an ignition scope or scan tool to lock in on the problem it make the job that much more difficult. The GM Service manual also suggests inspecting the spark plugs wires first on the diagnostic list for this code. I am not saying I am right or wrong either and am simply offering advice to check things but nobody on a forum has access to the car except the owner and his mechanic and often problems like this can be difficult to pinpoint online so all we can do is offer suggestions to help out. You can never diagnose too much when tracking down a problem and I was always told in college never to trust anything without proving it and seeing it with my own eyes so that is what I have always gone by. I have seen a lot of things that just dont make any sense at all but hey thats what mechanics deal with every day. A brand new spark plug someone else installed with no ceramic on the center electode is a real treat to diagnose!
  12. #12 Re: trannyman can u help
    Feb 2009
    lima ohio
    i just got back on i couldnt log in all nite well that gives me some hope
  13. #13 Re: trannyman can u help
    Feb 2009
    lima ohio
    i checked dealership they changed upper intake gasket and put in platinum plugs at 95000 could them plugs be bad already?platinum i think
  14. #14 Re: trannyman can u help
    Fort Wayne, IN
    They likely changed the gasket because it was causing a vacuum leak which can make the engine run lean and also give the problems you had if it was a bad leak but typically you have a lean condition code to go along with it. If it had the original spark plugs with 95K miles then they were way past due. Often most vehicle manufactures rate the ignition components to go to 100K miles but that is often way past due so your spark plugs were probably very worn and also causing misfire.
  15. #15 Re: trannyman can u help
    Feb 2009
    lima ohio
    so if they was changed at 95000 and its 130000 start out by changing plugs by the way thanks for all your expertise and knowledge
  16. #16 Re: trannyman can u help
    Aug 2008
    TN
    I'm stuck now. I had a MAF, & misfire on #5 code. I changed the MAF, & changed the spark plugs. I had no codes for about 5 minutes. My SES light start blicking. Putting #5 misfire code back. So I then change my wires and replace the #5 plug again. Ok for about 5 minutes again then again does same thing. I then go and change my coil pack for the #5 plug.
    Still putting the same code in.
    My car runs good except when it is sitting in park. you can then hear the mis in the engine and the SES light keeps blinking until you take it out of park.
    where should I go next?
  17. #17 Re: trannyman can u help
    Fort Wayne, IN
    You could possibly have a bad coil that is arcing internally or you could have a clogged injector that is causing that cylinder to run a bit lean. Did you check the condition of the coil terminals to the spark plug wires when you replaced them? It is very common to see rust or corrosion here and it can definately cause a misfire. An easy way to check out the injectors is to go around to each one with a stethoscope and listen to the sound they make. I have an injector pulse tool that is purpose meant to check the spray pattern and output of the fuel injectors but is not something that is too easy to come across and requires removing the fuel rail from the car. A compression test will also verify that the cylinder is mechanically sound or at least is close to the other 5 if it is then you are left with fuel and spark.
  18. #18 Re: trannyman can u help
    Bastard Reptile's Avatar
    Kansas City, MO
    You can also take a long dowel rod and hold it to your ear while you touch the injector. Cup your hand around the end of it, and over your ear, and you can hear lots of things going on with it.
    The best part is it only costs about $1.
    That's how I roll. LOL
  19. #19 Re: trannyman can u help
    Fort Wayne, IN
    Good tip! I have also heard or using a long skinny screwdriver and that works decent also. Both save a trip to the auto store
  20. #20 Re: trannyman can u help
    SE Level Member coolken84's Avatar
    Apr 2008
    Have you checked the plug wires as well? I had a similar problem on another vehicle that had a teeny tiny cut in a wire that was arcing to the block.
  1. Trannyman please help
    By kingbrentdwyer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-17-2009, 07:21 PM
  2. 14* of KR..........Trannyman?
    By t24moore in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-16-2009, 11:18 AM
  3. Trannyman
    By black.gtp in forum Off Topic Discussion
    Last Post: 07-26-2008, 11:04 PM
  4. Trannyman Help Me!!
    By GTX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-03-2008, 09:04 PM
  5. hey trannyman!!!!
    By yokosgs in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-06-2008, 11:15 PM
