Installed a new transmission pump, pump shaft, thrust washers for the channel plate and torqued everything properly. The transmission shifts fine now except it get a P0741 and no TCC lockup. At least it moves!
No Movement at all in this case = 3 loose 10mm bolts in the channel plate below the transmission pump.
