Thread: new guy need help 02 gtp tranny poblem
Results 1 to 7 of 7
  1. #1 new guy need help 02 gtp tranny poblem
    Feb 2009
    houston
    I have an 02 gtp auto that won't go into drive, but will go into reverse, 1 and 2nd . Lifted car everything looks normal axle wise no slop at differential, but when in 1st gear with car on jacks I can hear wierd noise, any possible help need opinion could it be differential, or rebuild.
  2. #2 Re: new guy need help 02 gtp tranny poblem
    Oklahoma
    Welcome to the community.
    Moved this to the correct area.
  3. #3 Re: new guy need help 02 gtp tranny poblem
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Sounds like a broken forward apply band. If you drop the lower pan and look at a windowed out section in the case just behind the filter towards the passanger side you will see the end of the band where the servo pin applies it. You will likely find that the end of the band is broken or there is about a 1" piece of broken band laying in the pan. Not real common but it happens enough that I see it now and then and it seems the 00-03 model years are the worst for this. Unfortunately if the band is broken it means a complete overhaul as it is one of the last parts to come out of the case.
  4. #4 Re: new guy need help 02 gtp tranny poblem
    Barksdale AFB, LA
    You can see the windowed section he's talking about in this pic from my shift kit install:
    http://img.photobucket.com/albums/v3...9/DSC02684.jpg
    2009 Subaru Impreza WRX STI
  5. #5 Re: new guy need help 02 gtp tranny poblem
    Feb 2009
    houston
    Quote Originally Posted by Trannyman95 View Post
    Thks for your support you hit it right on the button thats what it was, do you know if there is a revised upgrade or are they still manufacturing the same band. Again thank you, alot the shop showed me the 1" piece. So I know I'm not getting the run around, keep up your forum support.
  6. #6 Re: new guy need help 02 gtp tranny poblem
    Feb 2009
    houston
    Quote Originally Posted by sabrewings View Post
    you can see the windowed section he's talking about in this pic from my shift kit install:
    http://img.photobucket.com/albums/v3...9/dsc02684.jpg
    thks for your pictures and help keep up the good work helping others
  7. #7 Re: new guy need help 02 gtp tranny poblem
    Fort Wayne, IN
    I have not had a trans come back with a broken band after installing new ones so I dont know if it was an isolated batch or what the deal was. The only changes that I have seen were a few years ago the friction material was changed but dont see any changes on the metal part itself.
  1. FWD 3.8l to RWD tranny
    By static2489 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2008, 02:26 PM
  2. 9C1 Tranny Help
    By cobraz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-25-2008, 11:36 PM
  3. What tranny comes with my car?
    By 2000GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-23-2008, 11:36 AM
  4. Tranny???
    By Darkcelle in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-06-2008, 10:36 AM
  5. New Tranny plus ??????'s
    By Sherif41119 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-26-2008, 03:24 PM
